500W of ICEpower for USD0, deal or not?
Old 19th September 2019, 11:53 PM   #191
hifiamps is offline hifiamps  United States
Yes, if you don't plan to use them in your setup.
Old 19th September 2019, 11:57 PM   #192
erozsolt is offline erozsolt  Hungary
Thanks, I didn't know I can pull them!
Old 20th September 2019, 12:07 AM   #193
YouTube
Use an Xacto blade to pull up the white retaining tab and pull the wire out.
Old 20th September 2019, 01:31 AM   #194
mortron is offline mortron  Canada
Originally Posted by hifiamps View Post
Correction: balanced so no need to twist inputs to 125. Connect Channel 1 (pin 8) input to (-) XLR and Channel 2 (pin 5) input to (+) XLR. Connect Ground XLR to two ground inputs (pins 6 and 7) and BTL input (pin 1). See Fig 17 in the 125 manual. It shows unbalanced input with inverting opamp on Channel 1. But (-) XLR replaces inverting opamp.
Thanks for this and the previous post to this. Exactly what I was looking to do. I will need to get to examining this on the weekend. Have you done this on your own amps, and what were your findings? I am running a Triamped setup and want to use these for mids. Thanks again!
Old 20th September 2019, 04:11 AM   #195
I have not done it yet. Haven't had time and waiting for parts for active balanced line driver. Plan to connect a balun I have first, and see how it sounds.
Old 20th September 2019, 10:46 AM   #196
TimmyS is offline TimmyS
https://smile.amazon.com/dp/B01N1RFZ...v_ov_lig_dp_it
Supposed to be a decent crimper for cheap.
Old 20th September 2019, 01:07 PM   #197
rootbeer is offline rootbeer  United States
hifiamps, what circuit are you going to use? BTL? Perfboarding it?
Old 20th September 2019, 07:46 PM   #198
I'm doing BTL with the NE5532 balanced line driver described in Elliott Sound website, with the 317/337 regulator with Maida output and adjust RCs on perfboard. Using 1000uF plus input caps with 3R0 series resistors to the +/- 24V 125ASX2 supply. The two 1uF film caps are fairly large, but from past experience with the 317, I think it sounds best that way, very sharp, precise but smooth. The bigger caps on the output make the regulation too slow to transients, and it sounds "fuzzy". If it doesn't work, the electrolytics would substitute in the space without a problem. Using a lot of 100nF multi ceramics to silicon supplies as recommended.
Old 20th September 2019, 09:07 PM   #199
Bought some NE5532s from hstbeto on eBay listed as "ti". Don't waste your time, Chinese junk, clearly fake logo. Seller hasn't responded to my email.
Old 21st September 2019, 01:09 PM   #200
Aren't those like a buck a piece? Why ebay?
500W of ICEpower for USD0, deal or not?Hide this!Advertise here!
[FS] ICEpower 200ASC + ICEpower 200AC sipsik Swap Meet 25 3rd November 2017 01:37 AM
Power Supply for 500W+500W Amplifier Pittbull Power Supplies 24 28th October 2010 11:13 AM
Selfoscillating HalfBridge 500W+500W by IR. Interested? deflorator Class D 0 10th October 2004 03:30 PM
Copyright ©1999-2019 diyAudio
