Mosfet Limitations in class D amp
Old 21st July 2019, 09:18 AM   #1
badboy6120 is offline badboy6120  Malaysia
Default Mosfet Limitations in class D amp
Hello all
I'm working on my 1000W rms half bridge class D amp and want to choose the best mosfet suited to this much power
I used IRFP4227 with more than 1000W rms for half an hour with everything ok
the rail voltages are +-110 V
as I calculated from the below equation I need a mosfet with at least 214V reverse breakdown voltage(250V mosfet)
2*root((Output power *Load ohms * 2)/0.85)+10%
2*root((1000*4*2)/0.85)= 194V
194V + 10% = 214 V
Am I using the right calculations??
**** ONE KIND WORD can change someones's entire day ****
Old 21st July 2019, 02:19 PM   #2
MorbidFractal is offline MorbidFractal
VLoadRMS = Root(Power*R)
VLoadRMS = 63.24V
VLoadPeak = Root(2)*Vrms
VLoadPeak = 89.44V
VLoadPeakToPeak = 2*VloadPeak
VLoadPeakToPeak = 178.88V
In an ideal world that is the required Vds rating of your mosfets.
Then you apply your fudge factors.
Major is the maximum duty cycle your modulator can achieve. [Your 0.85?] Next would likely be RDSon and other losses. [Your 10%?]
As to why your mosfet survives. It would help if you read the data sheet...
https://www.infineon.com/dgdl/irfp42...53562927642004
Repetitive Avalanche Capability for Robustness
and Reliability
In particular look for the word Avalanche and also refer to the transient thermal impedance curves.
The main numbers are quoted as being energies so the application will generally involve inductive turn off where that energy will be defined by the inductor being turned off and the current through it at turn off.
So... yes you can exceed the VdsMAX rating of 200V but that depends on your application, whether you can do the sums and how lucky you feel.
Also note that the 240V figure is given as being typical and as such you cannot rely on it. In the case of a half bridge if you avalanche one mosfet whilst the other one is switched on things will blow up very quickly.
File Type: png Screenshot from 2019-07-21 14-38-33.png (153.2 KB, 134 views)
File Type: png Screenshot from 2019-07-21 14-39-01.png (33.9 KB, 133 views)
File Type: png Screenshot from 2019-07-21 14-40-11.png (42.1 KB, 135 views)
File Type: png Screenshot from 2019-07-21 14-40-43.png (94.4 KB, 134 views)
Old 22nd July 2019, 03:34 AM   #3
Hello and thanks for your reply
I'm using IR2110 as mosfet driver and the duty cycle should be around 85%
about those numbers in my calculation I found them in the below article (top of page 3)
https://www.google.com/url?sa=t&sour...=1563765523452
yesterday I ordered 2 different mosfets with higher BVDS
IRFP4768
IXFK64N50P
the second one has much higher voltage rating (500V) RDSon 85 mOhms
totall gate charge 150nC
T on = 30ns
T r = 25ns
T off = 85ns
T f = 22 ns
and high power rating
Old 24th July 2019, 08:28 AM   #4
manojtm is offline manojtm  India
manojtm's Avatar
HI,
IRFP4768
IXFK64N50P
Both one huge Ciss (need a totem pole to drive)
MANOJ
Mosfet Limitations in class D ampHide this!Advertise here!
Class B amp with Mosfet indr Solid State 10 25th August 2018 03:04 PM
mosfet class a/ab amp p robertson Solid State 30 9th February 2010 11:07 AM
help!ab class mosfet amp mbonus Solid State 31 19th September 2005 04:14 PM
JLH Class-A in a with MOSFET's tschrama Solid State 3 10th February 2002 03:23 PM
Copyright ©1999-2019 diyAudio
