Picking Output Filter Parts
Old 12th June 2019, 11:10 AM   #11
doctormord is offline doctormord  Germany
doctormord's Avatar
T106-2 is always a good choice, Coilcraft MA5173-AE are from the same core material.
Old 12th June 2019, 12:50 PM   #12
peroz is offline peroz  Slovenia
I am trying to find some inductors as well, and I asked in another thread, but the anwer I got was, that the inductor should have been tested to a frequency, higher than the switching freq. of the amp. The amp is 3116 mono.
Can't find one like that...
Would any of these be okay for a 22uH one:
Obročaste dušilke | Elektronske komponente. Distributer in spletna trgovina – Transfer Multisort Elektronik
Old 12th June 2019, 01:04 PM   #13
chermann is offline chermann  Austria
Hi
my idiea:
TPA3116 mono => PBTL = datasheet write 10H
i use at my dual mono chip amp the bourns 10H its small size SMD
Bourns SRP1250-100M
cost 1,8 euro at conrad and the datasheet give me a good current availibility thats fit to the max current of the tpa3116 amp.
chris
Old 12th June 2019, 02:21 PM   #14
doctormord's Avatar
If it has to be 22uH:
DTMSS-20/0.022/10-V FERYSTER - Inductor: wire DTMSS-20/0.022/10V | TME – Elektronske komponente
If you're limited to TME, then better go for Ferrocore inductors like these HCI:
Ferrocore HCI2114
with 15 or 22uH.
Old 13th June 2019, 07:20 AM   #15
Thanks for your replies, guys.
I want the 22uH because of these guidelines:
TPA3116 D2 mono amplifier as a stereo system?
for 8Ohm speakers.
I like TME because my company has quite good discount and we buy from them weekly.
I don't know how to work with SMD, that's why i never even checked the Ferrocore ones.
Is external filter a good idea or is it better to just change the components on the amp pcb?
Old 13th June 2019, 01:33 PM   #16
doctormord's Avatar
Just change at PCB, the Ferrocore inductors are usable with wires connected to as the conductors are wide enough for easy soldering.
Old 13th June 2019, 06:13 PM   #17
Hi Doc
Can you explain me why you use at PBTL a 15-22H instead of 10 as the datasheet?
thx
chris
Old 13th June 2019, 08:40 PM   #18
doctormord's Avatar
10uH is out of stock, and it isn't important if BTL or PBTL, speaker impedance is what counts. If you still have 8R even at PBTL, 15-22uH is perfectly fine. In the end it all belongs to the desired filter frequency.
Old 13th June 2019, 08:41 PM   #19
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I wind my own from t106-2 cores.
About a dozen turns gives 10uH
PCBCAD51 download or CDROM 2019 version out now https://www.murtonpikesystems.co.uk
Picking Output Filter PartsHide this!Advertise here!
Building an Audio Cart for school. Need help picking parts! AACT AV Crew PA Systems 2 26th March 2017 01:40 AM
Picking out parts for this schematic Seb1929 Parts 99 28th April 2015 05:21 PM
Picking an output transformer: power vs. sound quality gar3th Tubes / Valves 7 3rd February 2014 02:18 PM
Picking replacement output devices for Yamaha M-45 geaugafletcher Solid State 1 10th July 2012 04:55 AM
Picking LM3875 gainKlone parts 900mhz Chip Amps 3 2nd April 2005 02:12 PM
Copyright ©1999-2019 diyAudio
