600W Class D amp
600W Class D amp
Old 31st May 2019, 06:54 AM   #11
badboy6120 is offline badboy6120  Malaysia
Here's the latest schematic:
New 2.png - Google Drive
**** ONE KIND WORD can change someones's entire day ****
Old 31st May 2019, 07:00 AM   #12
thimios is offline thimios  Greece
Can you post the pcb?
Old 31st May 2019, 07:33 AM   #13
manojtm is offline manojtm  India
manojtm's Avatar
now the problem is that I can not get more than 600W rms out of this amp on a 4 ohms load despite using a +-90 volts supply
(I get about 70 volts peak output and after that clipping start. at clipping point I have about +-84V on amp rails)
90v supply rail you will get more than 600W. you said you get 70v on output at 4R load. it means you get more than 1000W
for higher voltage you need to set FB resistor to get 29dB~32dB Max. gain
MANOJ
Old 31st May 2019, 07:43 AM   #14
i'm still using manojtm pcb design V. 01(two seperate pcb)
you can find it here:
ucd 25 watts to 1200 watts using 2 mosfets
posted by Dear MANOJ
Old 31st May 2019, 07:52 AM   #15
MANOJ
Hi dear MANOJ
I want to build two separate amp that each capable of delivering 800W rms @4 ohms load for my subwoofers
right now I get 70V peak output voltages that is about 50V rms that deliver about 625W rms @ 4 ohms
I know that for 800W @4ohms I only nead +-80 volts but to lower my SMPS output voltage I have to reduce 1 turn of each secondary winding that will cause to reduce the voltages below +-80 Volts
Old 31st May 2019, 07:54 AM   #16
Can you help me with that?
Old 31st May 2019, 08:20 AM   #17
manojtm's Avatar
Old 31st May 2019, 08:32 AM   #18
manojtm's Avatar
for L use T157-2 core 1.5mm wire 49T (22uH)
High Volt(85v) use 47K (68K),56pF(100pF), 4K7/3W(2K2/3w) and add limiter circuit to avoid clip
MANOJ
Old 31st May 2019, 08:46 AM   #19
MANOJ
I don't have T157-2 at the moment and only etd 39 & etd49 & T106-2
I will buy it then if above core doesn't do the job
Old 31st May 2019, 09:04 AM   #20
I don't know why but I get about 185KH frequency with 1K resistor and 135KH with 560 ohms resistor
with 1k resistor:
IMG_20190531_132441.jpg - Google Drive
with 560 ohms:
IMG_20190531_132213.jpg - Google Drive
Time/Div is set to 2us
Ps: the measurements is from before the L(mosfets output) and GND
600W Class D ampHide this!Advertise here!
PA 600W netuddki Solid State 7 20th February 2017 10:45 AM
600W Class D TAS5624A Amp, with USB, HDMI, Bluetooth, and RasPi for Network Streaming brentsinger Class D 17 8th April 2016 02:42 PM
Help for 500-600W 50V PS rsjaurr Power Supplies 3 23rd March 2014 08:19 AM
FS: Plate Amp 600W Class D Rodan Swap Meet 2 3rd April 2013 12:50 AM
NEED A 600W@4E AMP .............WHICH TO START WITH sekhar Solid State 21 17th September 2012 08:56 PM
Copyright ©1999-2019 diyAudio
