600W Class D amp
600W Class D amp
Old 6th July 2019, 04:27 PM   #91
AudioSan is offline AudioSan  Norway
is there a reason for this posting?
you don't need te teach me about peak and rms. but you need to stop mixing them.
Old 6th July 2019, 08:27 PM   #92
badboy6120 is offline badboy6120  Malaysia
Thank you dear monaj for your helps
here's the latest schematic
any problem?
AUD600.Ver.2.jpg - Google Drive
**** ONE KIND WORD can change someones's entire day ****
Old 7th July 2019, 05:46 AM   #93
manojtm is offline manojtm  India
manojtm's Avatar
ok. only thing you can increase resistor value (3K3/5W) to 8K8/2W.a good quality op-amp will consume less current. from 90v 8k8 can give 10mA TL071&72 will consume only 2.5mA Max. so both will take 5mA.
MANOJ
Old 7th July 2019, 06:17 AM   #94
manojtm's Avatar
badboy6120 only for you,
please measure output volt without any load on current configuration.
a) +/-85v supply rail 100Hz pure sine wave 1.4vpp signal
b) +/-85v supply rail 1000Hz pure sine wave 1.4vpp signal
MANOJ
Old 7th July 2019, 07:28 AM   #95
MANOJ
Hi sir monaj
thanks alot for helping
I will do that tonight and share the result but without any load the rail voltages goes to +-90V and 85V is when the amp is under heavy load
Old 7th July 2019, 07:51 PM   #96
MANOJ
with +-90V supply and feeding a 1.4V peak to peak sine wave I get about 108V peak to peak with 100Hz and 1khz(without any load)
Old 10th July 2019, 09:53 PM   #97
Good News
I increased the rail voltages to +-110V and now I could get more than 1100W RMS output power
Old 11th July 2019, 07:59 PM   #98
Hey guys
What's the best solution to reduce mosfets overheating?
parralleling mosfets?
or go for full bridge?
Old 13th July 2019, 06:15 AM   #99
I manage to controll the mosfet overheating by using seperate heatsink for mosfets and remove the isolator between mosfets and heatsink
I test this amp for more than an hour with more than 1KW rms in output by 100HZ sine wave
Old 17th July 2019, 08:04 PM   #100
Hey guys
I was wondering if the new supply votages(+-110V) will cause any damage to the mosfets (BVDSS)
my mosfets are 4IRFP4227
I test this amp with more than 1KW RMS output for an Hour but I don't want to damage the mosfet because of the drain source breakdown voltage
any help would be appriciated
600W Class D ampHide this!Advertise here!
PA 600W netuddki Solid State 7 20th February 2017 10:45 AM
600W Class D TAS5624A Amp, with USB, HDMI, Bluetooth, and RasPi for Network Streaming brentsinger Class D 17 8th April 2016 02:42 PM
Help for 500-600W 50V PS rsjaurr Power Supplies 3 23rd March 2014 08:19 AM
FS: Plate Amp 600W Class D Rodan Swap Meet 2 3rd April 2013 12:50 AM
NEED A 600W@4E AMP .............WHICH TO START WITH sekhar Solid State 21 17th September 2012 08:56 PM
Copyright ©1999-2019 diyAudio
