Spectrum of Class D 1kHz Signal Before/After Filter
Old 13th May 2019, 12:04 PM   #1
shadders is offline shadders  United Kingdom
Default Spectrum of Class D 1kHz Signal Before/After Filter
I have searched the forum, and multiple threads, but was unable to locate any pictures of a class D amplifier outputting a 1kHz signal, with the spectrum before and after the output filter.
I did search Google too - and none were easily found.
What has spurred this that when a class D amplifier is tested in regards to THD, they use a 22kHz filter, yet class A, A/B or other, they usually use a 80kHz filter. The claim is that nothing can be heard above 20kHz, so the use of 22kHz filter for class D is appropriate. I am ambivalent in this aspect, but i would like to examine any class D output above 20kHz with a 1kHz test tone.
As such, does anyone have links to existing spectrum plots of class D amplifiers with a 1 kHz test tone, before and after the output filter ?.
Thanks and regards,
Shadders.
Old 13th May 2019, 06:07 PM   #2
Mark Tillotson is offline Mark Tillotson
You can't see the spectrum properly on an audio analyzer, it goes up to GHz. (And RF spectrum analyzer's seldom go below 10kHz)
Old 13th May 2019, 06:54 PM   #3
I am looking for an oscilloscope output of the class D amplifier before and after the filter, where someone has calculated FFT of the signal.
AP refer to this as per the following website : Class d and linear power amplifier testing Slide 11 and 12 details, but i would prefer a graphic that i can post elsewhere and one with more detail than the AP slides.
Shadders.
Old 13th May 2019, 07:32 PM   #4
MorbidFractal is offline MorbidFractal
Model it. May not be the best example but...
Three Level PWM amplifier
Old 13th May 2019, 08:53 PM   #5
Thanks. I did want the plots for an actual amplifier so that there were no arguments that it is not representative.
I am surprised that such plots were not on DIY Audio - it would have been the first thing i did should i have purchased or built a class D amplifier.
Shadders.
Old 13th May 2019, 11:32 PM   #6
kokoriantz is offline kokoriantz  Lebanon
Since a month I am learning about class d amplifiers, and as you I am looking for real measurements . If I found much more about PWM for motor drive than audio , but It gives good understanding about distortion due to dead time . Document AN1071 from IR shows scope pictures of DT distortion for 40ns and 15ns , but TI patent REDUCTION OF DEAD-TIME DISTORTION IN CLASS D AMPLIFIERS - Patent application (Pure Path) explains things differently . The distortion is very similar to cross over type with 5th harmonics .
Spectrum of Class D 1kHz Signal Before/After FilterHide this!Advertise here!
Testing tubes with a 1khz signal Dlav Tubes / Valves 4 29th October 2017 05:21 PM
Class D amplifier 1KHz, 5.5KHz IMD measurements longitude Class D 0 10th April 2017 12:09 PM
Fliege 1kHz notch filter project PCB agdr Equipment & Tools 85 6th February 2017 10:50 PM
1kHz bandpass filter for azimuth adj? Tim88 Analogue Source 2 14th June 2016 07:39 AM
2x100MHz PC USB Oscilloscope, Spectrum Analyzer, Multimeter, Signal Generator* VIRTINS Vendor's Bazaar 24 2nd August 2011 04:40 PM
Copyright ©1999-2019 diyAudio
