Hi all,
I'm wondering if anyone has any experience with the WONDOM brand that could tell me whether the following would work. Unfortunately, the company isn't too good at documenting their products properly, nor providing support within a reasonable amount of time, so I'm asking here (attached).
FYI, the reason I'd prefer this setup over any pre-fab options they have is as follows:
- The JAB3 options have DSP and Bluetooth, but the battery pack can't be connected to the amp while charging. I'd like to keep everything as-is no matter the state: charging or discharging. Moreover, the on-screen bluetooth name can't be changed.
- The older JAB2 amps can be charged while connected, but do not have built-in DSP, and their Bluetooth name can't be changed either.
I hope that, with this setup, I can get DSP and the amp to work together for a reasonable price. I'll add the third-party customizable bluetooth receiver later, but that should be easy. So yeah, any experience with these? I'd love to hear whether this will work.
i don't think you get any documentation about the dsp from them. your on your own unless your a big customer with $10k :/ order.
i have a jab2. no boost converter, so i think is running directly from the battery pack. which means the tpa3116 is only able to do half its output power. Quality and noise floor seams to be good. bluetooth works. Vol pot seams to be a bit scratchy these days... hmm :/
i think it also drains the battery flat after a month. unless its the little volt meter i added. i assume its the amp. best to leave battery disconnected for long periods.
womdom/sure seam to make good products. though with a cost optimised design. works, does the job but perhaps not as well as something 2x more expensive but hard to beat.
I use there dc-dc boost converters. seam to work great. not noticed them adding noise to audio. looks like better caps i guess then cheapo boards.
in my latest order. the idiots marked the value as 100. despite asking me. so now i have a £40 vat + handling bill from tnt. lesson is if doing orders that will be in a box bigger than say 25x20cm. Ask them to spit order up in to multiple packages with your local vat limit. means paying more for postage but its half the cost of a vat bill. the handing fee is half the bill!
I don't know about the handling fee but the VAT should be a fixed percentage. That means, unless each package is under a limit which makes it cheaper or free, it will cost the still the same.
Yes, the documentation is a really weak point and you can't expect there will ever be one provided by Sure/Wondom. However, if you are able to read German, here are some really helpful links:
Der Sure DSP Thread, Elektronik - HIFI-FORUM
Sure Electronics DSP DIY-HiFi-Forum.eu
Sure DSP Wiki <- Wiki
Looks good! Thanks
Glad I could help.
I guess I'll buy from an importer here in Europa to get rid of any such fees on receiving.
It's not only the tax or the fees, you have to wait and wait and then effort and get it. Really annoying.
I'd suggest to buy there (right around the corner ): SoundImports.eu - SoundImports
And I very strongly suggest to absolutely avoid the German importer.
- Class D
- Wondom Amp/DSP
