Repair Help
Repair Help
Old 13th May 2019, 06:43 PM   #21
ncred02 is offline ncred02  United States
I put a meter on the AUX output and Im getting 24v
Old 13th May 2019, 08:25 PM   #22
russc is offline russc  England
Enable pin -
unconnected = amplifier enabled (On)
pulled down (connected to 0v) = amplifier disabled (off).
It will be connected to the circuit operated by the 12v trigger.
If I understand your recent posts, you have not yet established whether the Icepower boards are faulty? If so, it's tricky explaining how to diagnose.
Looking at your photos, your unit is switchable for 110/220v? This is different to the photos on the product link.
If you disconnect the 3 way & 8 way connectors (with all black wires).
You will then have -
mains connected.
Speaker connected (connect a speaker for testing purposes).
You then need to connect a signal to the input connector on the amp board.
This would be the 2 pins of the 8 pin connector closest to the speaker connector.
If the amplifier is working you will hear it.
If dead then you know it is faulty.
If the amplifier board is working then the fault must be with the input board across the end of the case. That's for another day.
Old 15th May 2019, 04:42 PM   #23
Originally Posted by russc View Post
Enable pin -
mains connected.
Thats correct. I hope to test it this weekend.
Repair HelpHide this!Advertise here!
Repair of TNT 200 Acoustat. anyone out there can recommend who can repair Rbrowner Solid State 1 11th February 2019 05:25 AM
B&K ST-202+ Repair mjstriker5 Solid State 22 11th February 2017 03:46 PM
jvc ax-411 repair help rediceman Solid State 3 5th October 2016 08:19 AM
UPS repair soundalot Everything Else 4 21st October 2011 01:55 PM
JL 300/4 - First Amp Repair greg_gorrell Car Audio 27 1st August 2009 09:59 AM
Copyright ©1999-2019 diyAudio
