Class D amp module
Class D amp module
Old 18th April 2019, 09:19 AM   #1
Sous is offline Sous  Ukraine
Default Class D amp module
My implementation of a high-end amplifier module based on a UcD modulator and a fully differential integrator.
The scheme is largely borrowed from B. Putzeys, but integrated circuits are used instead of discrete elements in the modulator and driver. Unfortunately, because of this, a few dB of linearity is lost in the output stage operation. However, the amplifier shows high performance.
THD+N 20Hz-20kHz, 1W-1/2Pmax <0.001%
IMD 18.5+19.5 kHz 1/1 1+1W to 20+20W<0.001%
Supply voltage range +/-25 - +/-60V
Maximum output level 34V RMS
Gain 26dB
2 Ohm ready
OPA1632(LME49724) dif preamp on board.
All the necessary stabilizers on the board. Only need bipolar powering, which greatly simplifies the connection. A step-down converter with an efficiency of 86% is used to power the driver IRS20957S. The power of the opamp and the modulator is carried out through two-stage stabilizers. The first stage on bipolar transistors, the second on the LM317 / 337. Minimum distance between stabilizers and op-amp.
The total delay of the modulator is less than 110 ns due to the use of the high-speed comparator AD8561 (7 ns).
Idle current is only 70 and 50 mA for V + and V- bus.
DC offset, OCP, OVP on board.
File Type: jpg IMG-1b4587af4ce1cfef56448d38dc9b13f6-V.jpg (430.6 KB, 498 views)
File Type: jpg IMG-831740f8ce64fa4abf78928f2bfe2f9d-V.jpg (76.0 KB, 521 views)
File Type: jpg IMG-c9f7a9c0f5cca22464c2c08fd0a40e1a-V.jpg (76.3 KB, 511 views)
File Type: jpg IMG-f4ad8e8462c55baa8b7d5ef31f55c4d9-V.jpg (473.4 KB, 489 views)
Old 18th April 2019, 09:28 AM   #2
Schematic
Old 18th April 2019, 10:10 AM   #3
some pictures
THD+N 1W@4.3 Ohm
Carrier and FET totem pole
same thing increased
modulator time response
THD+N 6kHz, 10W@4.3 Ohm, 40 kHz bandwidth
IMD 10W+10W 18.5/19.5kHz @4.3Ohm
Old 18th April 2019, 10:20 AM   #4
TNT is offline TNT  Sweden
Why the ancient LM stabs? No one uses them anymore....
More distortion to the people!
Old 18th April 2019, 10:29 AM   #5
This is a big exaggeration.
Old 18th April 2019, 12:14 PM   #6
FauxFrench is offline FauxFrench  France
Impressive.
Old 18th April 2019, 04:57 PM   #7
Thanks.
Old 18th April 2019, 05:08 PM   #8
Obviously. Seriously, a lot has happened in this filed since those where released.
What was your design considerations?
Old 18th April 2019, 05:41 PM   #9
Everything is as usual: reasonable sufficiency. As an option, the application on the TPS7A49 / TPS7A30, but it does not give any advantages.
Old 18th April 2019, 06:08 PM   #10
Easyamp is offline Easyamp
Easyamp's Avatar
Looks nice, but Samwha caps. I know they’re not the worst, but a few pennies more and you get Rubycon, nippon chemi, nichicon, Cornell dubilier, Panasonic, etc...
bumble bee tuna.
Class D amp moduleHide this!Advertise here!
Which class-D module you think the best iceman009 Class D 2 26th May 2013 07:08 PM
class D amplifier module,power amplifier module sunlight009 Vendor's Bazaar 2 19th October 2011 01:02 AM
D Class Module for 3 way DQ828 Class D 19 23rd December 2010 10:51 AM
Dlogixs class X module.. MatthewS Car Audio 1 6th April 2008 10:47 PM
Copyright ©1999-2019 diyAudio
