Linear power supply for amptastic mini-1
Old 21st March 2019, 11:32 PM   #1
ljbrandt is offline ljbrandt
Default Linear power supply for amptastic mini-1
I am soon to be in possession of 2 amptastic mini-1 digital amps (they use the ta2020 chip). I will be setting them up to run in a vertically biamped configuration with my desktop speakers. I'd like to feed them power from a astron regulated linear power supply, but I'd like to know if they can both be powered from a single astron unit, assuming it can provide enough amperage, such as an rs12a. Opinions appreciated
Old 22nd March 2019, 03:16 PM   #2
FauxFrench is offline FauxFrench  France
Astron RS12A should give 12V-12A (144W). With "vertically biamped" I assume you mean two TA2020 channels (2 per TA2020 chip) for each stereo channel. That can be done with a single RS12A. Make sure you have sufficient decoupling of the 12V either in the RS12A, outside of the RS12A or at the Amptastic Mini-1 boards. The RS12A seems to be designed for CB use.
Old 23rd March 2019, 12:56 PM   #3
Thank you. I read somewhere that the ta2020 chips cannot share a common ground, so I wasn't sure if that pertained to a shared power supply or not. It looks like a single astron lps would work then. Any suggestions on an alternative that may work better for audio? The astron seems to be a popular choice though for lower powered chip amps.
Old 23rd March 2019, 01:20 PM   #4
I am not sure about your concerns regarding "common ground". The TA2020 uses BTL and separate A-GND and P-GND. They have to be connected appropriately. As I see it, you can use a single supply.
Old 26th March 2019, 01:43 AM   #5
thank you
Linear power supply for amptastic mini-1Hide this!Advertise here!
mac-mini music server : linear power supply Vs high frequency noise absorber stephengrenfell PC Based 32 9th October 2016 08:25 AM
Linear DAC power supply jean-paul Analog Line Level 0 30th April 2015 10:53 AM
linear pc power supply? cowanrg Power Supplies 45 20th July 2012 02:49 PM
Linear power supply movie_fan PC Based 0 27th September 2011 12:47 AM
Copyright ©1999-2019 diyAudio
