150uh - 62khz-500khz Ferrite Which Core?
Old 22nd March 2019, 06:40 PM   #11
MorbidFractal is offline MorbidFractal
Originally Posted by birgitay View Post
10 spir will also burn in 2 / amps. If I did what I did, I didn't hold 150. What could be the ideal core?
You have to calculate a core area product. Winding Area x Core Area. Aw.Ae
What is the load of your amplifier?
What is the power of your amplifier?
What is the switching frequency of your amplifier?
What is the supply voltage of your amplifier?
Why have you chosen a 150uH inductor?
Old 22nd March 2019, 06:43 PM   #12
birgitay is offline birgitay
Amplifer power supply 2x85vdc.
Min freq ; 62khz - max freq ; 400khz
Mosfet transistor 2x irfp250
Old 22nd March 2019, 06:58 PM   #13
Oh.... One of those.
You missed out the load and the power.
Old 22nd March 2019, 07:04 PM   #14
schema here. Power is not clear
Old 22nd March 2019, 07:11 PM   #15
What power do you want and into what load?
Old 22nd March 2019, 07:25 PM   #16
The current power is good. I'm not quite sure but it could be 900w. 4 ohms.
Which core is required for this circuit?
Old 23rd March 2019, 03:50 AM   #17
abraxalito is online now abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Your core might well be suitable but you need to have a much bigger gap. Try five layers of paper tape.
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 23rd March 2019, 07:53 AM   #18
I tested the Rm14 core with five paper money. I left it after the transistor IR2110 failure. Not working, lit
Old 23rd March 2019, 11:56 AM   #19
OK. Ignore the rest. 900W 4R 15A RMS 21A PEAK
AwAe = LIrmsIpk/BpkJKcu
AwAe = (150u x 15 x 21)/(300mT x 4E6 x 0.7)
AwAe = 5.625E-8
Assume Aw = Ae
Aw = Ae = 2.37E-4 = 237mm^2
ETD49
Ae = 211mm^2
Aw = 269mm^2
Aw.Ae = 5.676E-8
Nmin = LIpk/BAe
Nmin = (150E-6 x 21)/(300mT x 211E-6)
Nmin = 50
More later.
Old 23rd March 2019, 01:19 PM   #20
Oh... The above assumes that you want 900W continuous rated power. If you assume music is 1/8 continuous then you can use a higher number for J, current density in the wire, and end up with a smaller inductor. You still have to design to avoid saturating the inductor based on the peak current though.
Once again why 150uH
150uh - 62khz-500khz Ferrite Which Core?Hide this!Advertise here!
AIR-Core Vs Ferrite-Core Inductor in Class-D amplifiers kASD Solid State 14 4th April 2016 01:26 PM
Can someone explain the difference between air-core and ferrite core corssover coils? Richard Davis Multi-Way 8 13th April 2014 04:53 PM
Ferrite core for Boost PFC inductor. treez Power Supplies 48 10th October 2012 10:37 PM
HELP with modifying ATX PSU and ferrite core calculations. DigiSoft Power Supplies 16 21st February 2012 05:57 AM
inductor/choke/air core/ferrite core. . . same thing? poolorpond Pass Labs 24 29th March 2008 10:55 PM
Copyright ©1999-2019 diyAudio
