Anaview: can you tie speaker ground?
Old 22nd February 2019, 02:42 PM   #1
mudihan is offline mudihan  United States
Default Anaview: can you tie speaker ground?
Question is whether I can tie the negative speaker outs of two Anaview modules (AMS0100-2300) together? In my specific set up, my stereo speakers will have to share a common ground due to how the wires are run behind the walls. I know some Class D amps cannot share one common ground, but I am not sure if Anaview is one of those types. Thanks!
Composing music>Playing Music>Listening to music>The equipments you use to listen to music
Old 22nd February 2019, 02:54 PM   #2
Khron is offline Khron  Finland
Send a message via AIM to Khron Send a message via MSN to Khron Send a message via Yahoo to Khron
http://www.anaview.com/sites/default...0AMS0100-I.pdf
Page 5 contains your answer.
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
Old 22nd February 2019, 03:04 PM   #3
Originally Posted by Khron View Post
Thanks, and got it. If I were to feed singled-ended signal to the amps and therefore tie the negative inputs to input ground, I assume this would not affect the feasibility of connecting the negative speaker outputs to the same ground?
Old 22nd February 2019, 03:29 PM   #4
Not at all. Which input you feed the audio signal into, doesn't change where that particular output pin is soldered, only the polarity of the output signal.
Old 22nd February 2019, 03:49 PM   #5
Thanks. Good to know -- this aspect of Anaview makes things much easier to wire. Now I may even use the amps to drive those hard-to-drive headphones, if the noise and DC offset are low enough.
Old 22nd February 2019, 06:24 PM   #6
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Doesn't it also depend on how you use them? If you use them in BTL (one module of 2 amps per load) you can't connect any output to ground.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 22nd February 2019, 06:30 PM   #7
... Nor would you need to
Jan
Old 24th February 2019, 06:20 AM   #8
doctormord is offline doctormord  Germany
doctormord's Avatar
The amp should shut down if you do, as this is a serious fault condition (short to ground).
Anaview: can you tie speaker ground?Hide this!Advertise here!
TDA7052A speaker mic ground Copper Dog Chip Amps 2 22nd May 2014 12:02 AM
Speaker protection and common ground ads2 Chip Amps 7 1st January 2011 11:42 PM
Speaker ground issue lowfrequency Everything Else 6 4th December 2008 01:20 PM
Ground loops, speaker hum and buz steevo Solid State 15 31st October 2008 09:58 PM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
Copyright ©1999-2019 diyAudio
