chinese ebay amp test - finally
Old 17th February 2019, 04:11 AM   #1
3rutu5 is offline 3rutu5  Australia
Default chinese ebay amp test - finally
guys,
thought i would share my experience with the TDA3116 2.1 ch amp board i purchased a month ago.
Cheap eBay TPA3116 amp
finally decided to hook it up and give it a test. I had a piece of scrap 30mm ply and decided to see if i could make a matching pc case from my recent speaker build only to rush into it and not think about the measurements. needless to say it was too small for a pc but could work with a logitech sub i repurposed from a old THX setup i had. tried two sets of speakers as well (which one was my latest build) and to be brutally honest what came out really stank. the Magnat satellites i had gave out a mechanical noise/distortion and struggled. The same issue was heard with the studio speakers as well, which i know now isnt the driver but the board itself. The bass from the sub was a bit average and i think less than the 3.5 inch tectonics i have.
If i was to compare it against the DTA-2 amp which generally power the studio monitors, i would have been confused that the 10w @ 8ohm per channel was a mistype.
both boards cost about the same, but i was expecting something equal to or better than the DTA's. tweaking the dials did nothing really either as the weird mechanical sound still floated around.
guess 25 AUD is still cheap enough to be a test, but not sure if that is to be expected from the ebay chinese boards.
Old 17th February 2019, 04:38 AM   #2
Jerms is offline Jerms  United Kingdom
Mechanical noises and distortion could be the chip resetting and restarting maybe? Check the caps and through hole soldering. Try another PSU. Looks like Bluetooth only input. Try moving that big choke on the PSU lead away from the Bluetooth aerial.
Some of this stuff does turn up broken. I may have been lucky so far. I have 11 boards in total.
J.
chinese ebay amp test - finallyHide this!Advertise here!
Modi 2 Uber or a Chinese DAC Off Ebay? SRMcGee Digital Line Level 23 17th January 2017 11:52 AM
Chinese WM8740 DAC from eBay mlihl Digital Source 0 20th June 2014 12:09 PM
Finally made a test load Conrad Hoffman Equipment & Tools 4 21st November 2012 08:53 AM
Chinese Kits EBAY tatolovera Chip Amps 5 22nd July 2011 07:05 PM
cheap Chinese amp modules on ebay . Anyone know what they are ? jives11 Chip Amps 36 28th November 2008 04:35 PM
Copyright ©1999-2019 diyAudio
