Setting up a Fusion Amp 3-way Step-by-Step
Old 10th September 2019, 02:24 PM   #71
ds23man is offline ds23man  Netherlands
ds23man's Avatar
In HFD?
Old 11th September 2019, 07:41 AM   #72
TimbreAudio is offline TimbreAudio  United Kingdom
So yes, I scanned through the whole manual, the first bit of "import speaker measurements" through me of the scent at first.
But near the end it does give instructions under Recording of how to record from within HFD.
I can't seem to get my behringher mic and pre-amp to work with REW or Fuzzmeasure, despite showing it seeing a signal on my mac. Maybe I can try with HFD later.
Old 11th September 2019, 08:09 AM   #73
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
I found it easier to run measurements in REW and set hfd manually in another window.
Radikal aktivist AINOgradient speaker project
Old 19th September 2019, 10:39 PM   #74
daemonsgr is offline daemonsgr  United Kingdom
if you want to use your existing preamp or AVR receiver, I assume volume works from the preamp and you just set a constant volume value on both plate amps? Like -10 lets say and its like the last gain stage of a power amp? Right?
All control from the AVR/PRE.
Setting up a Fusion Amp 3-way Step-by-StepHide this!Advertise here!
Designing a classD amp input transformer - step by step guide abraxalito Class D 31 10th June 2017 08:30 PM
Ferrite core transformer design step by step Aucosticraft Power Supplies 159 20th June 2015 02:20 PM
Home built 1" dome tweeters, with step-by-step pics flyingtele Multi-Way 3 3rd April 2011 09:11 PM
stuffing Mileva: first timer step by step questions schro20 Full Range 7 2nd June 2008 05:49 PM
Copyright ©1999-2019 diyAudio
