Setting up a Fusion Amp 3-way Step-by-Step
Old 25th March 2019, 07:32 AM   #51
_henry_ is offline _henry_  Australia
Originally Posted by ds23man View Post
When you make measurements in HFD you also register the offset of the drivers. To do this correctly you need exact timing between the input and output. This only garanteed with a usb souncard/mic preamp which share the same clock. If you use an Umik, this relation does not exist and the simulated responces will be wrong.
Whats the connection will look like?
Fusion - usb - laptop
UMC22 - usb - laptop
UMC22 - analog into fusion
Is this correct?
Old 25th March 2019, 09:24 AM   #52
ds23man is offline ds23man  Netherlands
ds23man's Avatar
Yes.
Old 28th March 2019, 04:23 PM   #53
Yes.
Im getting very low volume on fusion 253, set the output at 125w, 50w and 50w. Gain at 0, UM22 at max volume and it didnt have enough volume to get good measurements. Any ideas?
I tested the um22 on audirvana and it gives normal volume.
Old 28th March 2019, 04:28 PM   #54
I also tested the fusion with my speakers on audirvana (playing music on the midrange), it gives plenty of output...
Old 28th March 2019, 06:26 PM   #55
mspijker is offline mspijker  Canada
The UM22 outputs max 0 dBu (0.775 V), see https://www.strumentimusicali.net/ma...SERIES_ENG.pdf .
The Fusion amp needs 18 dBu (6.15 V) on the XLR input and 9 dBu (2.18V) on the RCA input for full power. If you're using the XLR inputs, you can try using the RCA inputs or increase the Fusion amp gain with the jumper described on page 17 of the manual. It looks like you'll need to do both (RCA @ 2dBu / 0.98V) if you want more power from the fusion amp. Or use a preamp.
Old 28th March 2019, 11:34 PM   #56
Thanks mspijker, i only have gain problem while measuring with HFD.
I got sufficient gain with normal playback though. Im wondering whats the problem here.
Old 29th March 2019, 12:50 AM   #57
Henry, I just ordered a pair of FA123s and a UMC22 but they haven't arrived yet. So I'm not writing from experience, just reading specs. How did you hook up the UM22 to the Fusion amps? What connection do you use for normal playback? Maybe ds23man has some good tips wrt HFD.
Old 29th March 2019, 04:01 AM   #58
Laptop - usb - UM22
Um22 - XLR - Fusion
Laptop - usb - Fusion
Normal playback is
Laptop - usb - um22
Um22 - xlr - fusion
Old 29th March 2019, 07:09 AM   #59
Originally Posted by _henry_ View Post
Laptop - usb - UM22
Um22 - XLR - Fusion
Normal playback is
Laptop - usb - um22
Um22 - xlr - fusion
Normal playback is with audirvana in mac
Hfd on windows7 in parallel wit asio4all
Old 30th March 2019, 03:38 AM   #60
The problem went away, not sure what was the issue....
Setting up a Fusion Amp 3-way Step-by-StepHide this!Advertise here!
Designing a classD amp input transformer - step by step guide abraxalito Class D 31 10th June 2017 08:30 PM
Ferrite core transformer design step by step Aucosticraft Power Supplies 159 20th June 2015 02:20 PM
Home built 1" dome tweeters, with step-by-step pics flyingtele Multi-Way 3 3rd April 2011 09:11 PM
stuffing Mileva: first timer step by step questions schro20 Full Range 7 2nd June 2008 05:49 PM
Copyright ©1999-2019 diyAudio
