Setting up a Fusion Amp 3-way Step-by-Step
Old 10th February 2019, 06:50 PM   #21
ds23man is online now ds23man  Netherlands
ds23man's Avatar
It was a Focusrite 2i2 gen 2.
Old 10th February 2019, 06:59 PM   #22
00940 is offline 00940  Belgium
00940's Avatar
Afaik, all Scarlett devices, 1st and 2nd generations, share the same cs4272. That's why I'm interested by the problems you had.
All that is excessive is insignificant. Talleyrand
Old 10th February 2019, 08:02 PM   #23
cowanaudio is online now cowanaudio  Australia
cowanaudio's Avatar
I'm interested in the nature of the timing problems too, because I have a 2i2 gen 2 that I intended to use for measurements with HFD.
Don't Procrastinate....Just Do It!
Old 10th February 2019, 08:15 PM   #24
mspijker is offline mspijker  Canada
How does the ADC/DAC (re)sampling in the FusionAmps fit in all of this? The FusionAmp's ADC & DAC run on a different clock than the microphone's ADC. Doesn't that introduce the same sampling uncertainty? Ideally you'd drive the Fusionamp with a digital input, digitize the mic with the FA's ADC and read it back through the USB to HFD. But I guess that that's not possible.
Old 11th February 2019, 06:09 AM   #25
ds23man's Avatar
They use the CS4277 as ADC and the AKM4384 as a Dac.
bo: Focusrite Scarlett 2i4 inside.
Old 11th February 2019, 06:29 AM   #26
00940's Avatar
The 2i4 needs the 2 extra output channels, hence the AKM. The 2i2 doesn't and only have the CS4272.
But that's not very important. What's more interesting is the problems you had and what we should be watching for.
Old 11th February 2019, 06:39 AM   #27
ds23man's Avatar
Two loopback measurements with the Scarlett:
https://www.diyaudio.com/forums/atta...1&d=1549870611
When you do let's say 10 measurements 1 is correct. With the Focusrite ASIO driver it's more worse.
Old 11th February 2019, 07:46 AM   #28
Windforce85 is offline Windforce85  Poland
https://www.diyaudio.com/forums/atta...etverschil-png
So basically, along your assumptions, Clarett 4Pre USB interface is also a crap? This is eye-opening.
Old 11th February 2019, 08:19 AM   #29
ds23man's Avatar
For this application: YES. Does not mather what software you use.
Old 11th February 2019, 08:37 AM   #30
ds23man's Avatar
I discovered this when I made new measurements of my 3 way system with the Scarlett.
When I made new filtersettings I got unrealistic delay settings, like the mid was shifted fisically 30 cm forward and the tweeter to the rear.
I think the XMOS chip is the culprit, so validation of the measurement setup will be a important part in the manual.
Setting up a Fusion Amp 3-way Step-by-StepHide this!Advertise here!
Designing a classD amp input transformer - step by step guide abraxalito Class D 31 10th June 2017 08:30 PM
Ferrite core transformer design step by step Aucosticraft Power Supplies 159 20th June 2015 02:20 PM
Home built 1" dome tweeters, with step-by-step pics flyingtele Multi-Way 3 3rd April 2011 09:11 PM
stuffing Mileva: first timer step by step questions schro20 Full Range 7 2nd June 2008 05:49 PM
Copyright ©1999-2019 diyAudio
