Hello,
I would like to buy 2 Class D amplifier modules (just the pcb with components) to drive the following speakers:
Woofer
220w RMS
440w PEAK
2ohm
38Hz – 1.8kHz
HF Driver
35w AES
8ohm
1.9k-20kHz
What are your recomendations in terms of already assembled boards that I could buy for these speakers?
thank you so much
best regards
Woofer
220w RMS
440w PEAK
2ohm
38Hz – 1.8kHz
HF Driver
35w AES
8ohm
1.9k-20kHz
thank you so much
best regards
Hello,
Woofer
220w RMS
440w PEAK
2ohm
38Hz – 1.8kHz
HF Driver
35w AES
8ohm
1.9k-20kHz
It is probably the amplifier for the woofer - 300W in 2 Ohm - that puzzles most of us.
As a good amplifier for the HF driver (35W/8Ohm) I can propose a TPA3250 based amplifier. High quality sound.
300W in 2 Ohm means high current levels. For car audio this is trivial, for HIFI/audiophile use much less. Perhaps a IRS2092 based amplifier with low impedance switches. Or, if you can find a TPA3255 based mono board with PBTL coupling.
You are not afraid of a sound-level imbalance with such a powerful woofer?
Hi, thank you so much for your help.
Unfortunatly it's the speakers I have, they are JBL EON 315 (PA/Stage monitor speakers) that have failled amps. those amps are crappy and prone to failure so I ditch them, and will power the speakers from a DIY Class-D amp assembled with modules.
The woofer in these JBL EON 315 is model JBL M115-2 rated at 220w RMS at 2ohms.
So I guess I need to find a class D module that is able to work at 2ohms, can't seem to find one
table { }td { padding-top: 1px; padding-right: 1px; padding-left: 1px; color: black; font-size: 12pt; font-weight: 400; font-style: normal; text-decoration: none; font-family: Calibri, sans-serif; vertical-align: bottom; border: medium none; white-space: nowrap; }
Do you know a webstore or model I could buy?
what could be your recomendations for modules using the TPA3250?
Thank you
I will suggest you to look at the modules from Sure Electronics and 3e Audio. With the power you need for the woofer, I will recommend you to buy from manufacturers that are known for more solid designs.
The Sure Electronics pdf document includes in the beginning an overview of their boards. Here it is easy to find a board for your needs.
TPA3250 boards (without chassis) are more rare but 3e Audio has that.
Personally, I have none of these boards because I chose to settle with a significant lower power level my wife accepts.
Sure Electronics' webstore Mono Series
http://sure-electronics.net/Sure%20Electronics%20Audio%20Amplifier%20Product%20Manual.pdf
TPA3255-1CH-480W | 3e Audio
TPA3250-2CH-50W | 3e Audio
thank you so much for the links.
The Sure store has a lot of offerings, nice to know.
On the website is a bit hard to search for a specific amplifier module but the pdf you sent really helps on that.
I selected 2 amps that work at 2ohms for the woofer,
what do you think of these?
This one seems to have the right power but THD seems a bit high at 300w:
TAS56XX Series 1 X 300 Watt 2 Ohm Class D Audio Amplifier Board – TAS5613
AA-AB31191
http://store3.sure-electronics.com/1-x-300-watt-class-d-audio-amplifier-board-tas5613
or this one, has more power but will less less THD at 220W:
http://store3.sure-electronics.com/1-x-600-watt-2-ohm-class-d-audio-amplifier-board-tas5630
1x600w
Output Power
600W@2Ohm 48V DC THD+N 10%
350W@2Ohm 48V DC THD+N 1%
__________________________________
For the HF Drivers, this amp seems good enough,
I saw the amps at 3e-audio, they look pretty good but the "Buy it Now" button doesn't work, so I can't see the price, it seems theres something wrong with the website
STA5XX Series2 X 100 Watt 4 Ohm Class D Audio Amplifier Board -STA508(AA-AB32186
Sure Electronics' webstore 2 X 100W Class D Audio Amplifier Combo Kit w MW 24V 200W Power Supply STA508
AA-AB31191
1x600w
Output Power
These are rated to handle 2ohm load (as the miniumum). I've not used this paraticulare one, but have a 250ASP running 2 4ohm coils in parallel without issues --
ICEpower 500ASP Class D Audio Amplifier with Power Supply Module 1 x 500W
A big advantage of most ICEpower amps is they include the power supply so it takes almost no time to get one oup and running.
Hi Bwaslo,
thank you so much for your recomendation, although the price is much higher than the Sure options.
Well maybe the quality is much better than the Sure product, I'm just a newbie on this stuff, also the PSU is included but even with an external PSU the Sure untis are 1/3 the price of the IEC
Thank you
Thank you
Of those I would prefer a TAS5630 based amplifier to a TAS5613 based amplifier simply because the TAS5630 chip has more power reserves and presumably better power handling stability.
When you pull 300W in 2 Ohm from a single chip amplifier the currents are (very) high and stability is an important issue.
I would worry less about still good THD levels because it is for a woofer that will not reproduce much of the higher frequencies from eventual amplifier distortion and how much distortion do you think your woofer will contribute with at that power level?
I guess you do it for the bass "kick" rather than the subtle sound.
I can do maximum 2x100W (8 Ohm) with any of my amplifiers so I have no experience at that power level.
No, I cannot get to the prices either. I tried with both my Linux machines and my wifes Win10. No reaction.
But, Ebay: TPA3255 1x480W 1Ch Class D Audio Amplifier | eBay
Illogical that you cannot get to their own web-shop. The Ebay price seems fair.
DOES ANYONE ELSE KNOW HOW TO SHOP AT 3E AUDIO?
Hi my friend
here is/was a group buy...
https://www.diyaudio.com/forums/class-d/309813-wrong-tpa3255-70.html#post5657613
i guess contact him for more informations
chris
Check if the woofer uses 2 coils like in the JBL EON 15 G2 .
Could the speaker put out more then half power when the bass was not cut?
Does it need to be as loud as it was before? As half power is only less then 3dB less output.
Group buy: TPA3251_TPA3255 Amplifier board and ADAU1701 DSP Pre-Amp board
This is the current group buy for the 3e modules.
Hello Think,
thank you so much for your message.
I'm sorry but I'm a newbie when it comes to this...
How can I check if the speaker uses 2 coils?
"Could the speaker put out more then half power when the bass was not cut?
Does it need to be as loud as it was before? As half power is only less then 3dB less output."
I'm sorry could you please rephrase this or explain it for dummies?
thank you so much
No problem: does the woofer have double + and - connections? So 4 instead of 2 terminals to connect wires coming from the amp to.
The speaker has a bass cut option for use as vocal monitor or pa top. It could well be that you can only get full power from it when this function is on and it does not play bass.
Just consider if you ever used all the specified watts. When used in full range 100W might already be more then enough; more then you ever use or even more then technically possible. (the woofer can handle)
No, just 2 terminals, I opened it up and checked that
No, you always get the full power.
Low cut is on the mic input of the preamp, it has nothing to do with the power amp
LOLOLOL
Mate this is a Sound Reinforcement speaker, for Live PA or Live floor monitor.
100 watts is nothing in the sound reinforcement world.
The rating of 350watts of the JBL Eon 315 is already on the Low side for a small PA.
For example this is a standard Floor monitor (wedge) that I use all the time in concerts, and it's a standard in the industry:
Martin Audio LE1500
RATED POWER (2)
FR/LF: 600W AES, 2400W peak
HF: 80W AES, 320W peak
RECOMMENDED AMPLIFIER 800-1500W into 4 ohms
https://martin-audio.com/downloads/archive/datasheets/LE1500datasheet.pdf
Vocalists get 2x LE1500 in front of them, Drummers also get 2
Thanks for your help, I'm being honest I really appreciate it, but bear in mind that Power used in Sound Reinforcement is not the same as in Hi Fi systems.
Thanks once more
+1 doctormord
and I guess they are lying about the real specs and people who think that max gas consumption is an indicator for top speed for cars, buy them.
Power Handling Vs. Efficiency
Doubling power is only +3dB minus extra power compression.
- Class D
- Class D amplifier - DIY modules recomendation
