iNuke 1000 - modifying crossover freq
Old 4th February 2019, 09:17 AM   #1
fatpizza is offline fatpizza  Romania
Default iNuke 1000 - modifying crossover freq
So I have the non dsp version because I was using Peace with the onboard 5.1 soundcard as a digital crossover.
Now I've switched to an USB DAC (Topping D10) and I am forced to rely on the 100 hz crossover switch on the iNuke to power my sub.
Anyone know how to modify the internal crossover of the iNuke to a more sensible 60-80 hz (preferably 12db slope)?
Old 5th February 2019, 07:31 PM   #2
Khron is offline Khron  Finland
Send a message via AIM to Khron Send a message via MSN to Khron Send a message via Yahoo to Khron
All that seems to be easily-found is the NU3000 schematic, but it's reasonably safe(?) to assume the lower-power version isn't too different.
On page 3 is the line-level circuitry, and the circuitry you'll want to focus on is the one around IC12-B. Looks to be a 3rd order low-pass - an RC low-pass in front of a 2nd order Sallen-Key filter.
Audio Designs With Opamps -2
Active Filters
ESP Download Page
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
Old 6th February 2019, 12:06 PM   #3
Active Filters
ESP Download Page
I filled in the values from the NU3000 schematic in this tool:
(Sample)3rd order Sallen-Key Low-pass Filter Design Tool - Result -
By changing C3 from 10n to 15n it gives me fc1 = 90[Hz] and fc2 = 78[Hz], which is what I need... I think.
Is there any need to change any other components?
Old 6th February 2019, 12:23 PM   #4
That depends on what you need, or what you're trying to achieve. And/or whether replacing capacitors is easier than resistors (or the other way around).
Old 12th February 2019, 03:53 PM   #5
I finally got around to messing with the amp.
I placed a 10n capacitor in paralel with the existing 10n capacitor giving me a crossover freq of 65Hz and it seems to be working just fine.
I have the amp hooked up via RCA to unbalanced TS adapters, and I noticed the amp works with just the inner contact of the RCA plugged in the adapter, is this normal?
Old 12th February 2019, 04:08 PM   #6
Glad to hear all is well.
And sounds normal enough, assuming the signal source is earthed somewhere (in order to complete the circuit).
iNuke 1000 - modifying crossover freqHide this!Advertise here!
Pls help with modifying DSP crossover Hydrogen Alex Digital Line Level 8 13th November 2018 03:12 PM
What crossover freq. for these 3-way drivers emretelci Multi-Way 24 5th August 2016 08:19 AM
Active crossover freq for TLK TL6 - suggestions? aspringv Multi-Way 2 10th January 2012 10:36 AM
Hi-freq Active Crossover Needed HipoFutura Solid State 6 30th July 2006 09:22 PM
HP crossover help (+ resonant freq) Dr. Apathy Parts 3 14th February 2006 12:39 AM
Copyright ©1999-2019 diyAudio
