TDA8954th btL amplifier
Thread Tools
Old 26th April 2021, 06:21 PM   #71
FauxFrench is offline FauxFrench  France
@ponyta,
You have done well and tell us important information.
When the amplifier is not connected to a source or the input is short-circuited, there is no noise. Thus, it seems not to be the amplifier power supply in itself that causes the problem.
When you use a source but stop the music playing, you clearly hear hum. Thus, the hum origins from the connection with the source OR, if you use a smartphone as source, the smartphone disables the headphone output when you stop the music in order to save battery.
First test for you to do is to connect your smartphone as source, without being connected to a charger, and play music from the smartphone while you slowly reduce the volume on the smartphone to zero (don't press stop or pause). This way the headphone output is not disabled. Do you still hear hum-noise?
Old 28th April 2021, 12:50 PM   #72
john_lenfr is offline john_lenfr  France
Hi FauxFrench, finaly changed my plan and re use an old hypex ucd180.
Tda stay in the box for now.
If ponita arrived at something good maybe I will test to modify the module.
Old 4th May 2021, 03:56 AM   #73
ponyta is offline ponyta
Thank you FauxFrench!
I did connect my board with a smartphone, play music, adjust volume to 0, and there no hum.
But whenever my hand touches the phone or the wire. I heard the hum, it is loud and sensitive even I come nearby the wire, not touch it.
Back with my subwoofer filter preamp circuit, I try with a different amplifier board (mono class a/b run 1pair a1943-c5200 transistors), it doesn't hum at all
(my preamp board quite similar here: NE5532 Bộ Lọc Thong Thấp Ban Loa Sieu Trầm Am Lượng Ban Module Khuếch Đại 9 15V Lọc Mo đun|Integrated Circuits| - AliExpress)
Reading tda8954 datasheet have some info, so I think maybe mass connect both 2 boards could fix that 50hz background hum.
(GDN mass connect, ground shield... etc I don't know what exactly it is or how to do. I'm so amateur, really need help).
ah, I am sorry for replying late, so busy with the living thing.
Old 4th May 2021, 07:33 AM   #74
I use a 24-0-24 transformer for tda8954 board and another 15-0-15 transformer for preamp filter board
Old 4th May 2021, 11:06 AM   #75
@ponyta
Is your TDA8954TH amplifier mounted in a metallic cabinet? Your pre-amplifier also? Do you have some loose zener-diodes?
Old 5th May 2021, 10:55 AM   #76
No, I just connected the boards together, all on the wooden tabletop:
A-preamp board
B-TDA8594 btl board
C-Mono A/B amp board
B, C run a 24-0-24V power supply and no hum when no input, A run a different dual 15Vs
A+C--> no hum
A+B--> hum
I just thought about floating input in tda 8954 datasheet
A and C have 0v as (-) sound in signal so just connect signal wire and they are grounded together
but B is BTL, I don't know whether sound signal (-) (0v in A) can be wired to 0v in B to fix hum??
Old 11th May 2021, 05:40 AM   #77
Sorry, this time I am late.
There are two types of constructions:
a) Those with two symmetrical supply lines (+ and -) with a further ground connection (called GND or 0V).
b) Those with only a single supply line (+ only) with a further ground connection (called GND or 0V).
The grounds are always connected together, never GND from a single supply construction to minus (-) of a dual supply construction.
Old 13th May 2021, 01:08 PM   #78
Thank FF, it seems there is no way to fix my board. I removed the rectifier bridge, use outside power but still nothing change about noisy hum.
Seeing some part of my board is not very similar to yours. I doubt it uses the wrong value of other capacitors. Also i quite want to fix it because this board gives a good bass quality (except it's noisy) i don't see in other board that cheap
Old 29th May 2021, 03:41 PM   #79
nkirk is offline nkirk
Hi @FauxFrench , Im looking for a amp to replace my aging tda8920( which loudly thuds at a rapid pace then gradually slows down to disappear at power on) board with a dual tda8954 chip board to drive my two subs (4ohms), power supply will be 24v, have two torroids available of the same model.
TDA8954TH Class D High Power Dual-Channel Digital Audio Amplifier Board 420W*2 700828400180 | eBay Is the one I'm looking at, my question is will it be an issue to use 4 ohm subs with the chips being in BTL mode and recommend to be used with 8 ohms. Not looking for high power, 200 a channel would do, more like 100 continues maybe with extra headroom to handle peaks at low freq around 20 30 Hz them being sealed subs.
Alternate option I have is the same single chip model you had an issue with highs being Sharp and distorting which required a snubber circuit correction.
Your help will be greatly appreciated.
Old 29th May 2021, 09:27 PM   #80
You can use a different speaker impedance than recommended if you eventually adapt the supply voltage. I will explain the considerations in detail for less experienced members. You can always use a higher speaker impedance than recommended without changing the supply voltage. The result is less maximum output power and for class D amplifiers a change of the frequency response in the high treble (due to a change of the output filter damping). The more tricky situation is when a lower speaker impedance than recommended is used and the load current increase.
We normally define the maximum output power as the output signal level where voltage clipping starts occurring. Thus, where the supply voltage limits the output voltage from going any higher (or lower). Voltage clipping typically starts occurring at a THD level in the order of 1%. Because amplifiers normally also include a current limitation for protection of the amplifier circuit, we could also talk about current clipping. The problem with current clipping is that it often arrives much more abrupt than voltage clipping and causes a much higher distortion. While voltage clipping causes a gradual increase in distortion when the clipping level is exceeded, current limit protection is included to protect the amplifier circuit without disregard to the distortion we notice. Some chip-amps can do an almost flat current limitation reminding of voltage clipping, but in particular class D amplifiers do dramatic things to limit the current. Therefore, the golden rule in amplifier design is that at no point is the current in the load, the speaker, allowed to exceed the current limit. For the TDA8954TH chip the current limit value is 12A (minimum and peak).
But as we consider the speaker impedance to be mainly resistive, we always have the possibility to reduce the maximum load current by reducing the supply voltage.
In the past the speaker was connected in “SE-coupling”, between the amplifier circuit output terminal and the ground wire (‘0”) for a symmetrical supply voltage. The maximum voltage across the speaker terminals was the voltage from one supply rail to ground. For the TDA8954TH chip that voltage is as an absolute maximum 42.5Vdc.
But, clever people realized that two amplifiers operating in counter-phase could be used for a single speaker such that the full rail-to-rail voltage could be put on the speaker terminals such that both the voltage and resulting current would be the double, and the power thus four times as much. This is the “BTL-coupling”. The problem with the BTL coupling is that you tend to loose track of the maximum load current and risk current limitation in the amplifier if not prudent.
For the TDA8954TH chip with an absolute maximum supply voltage of +/-42.5Vdc. the peak BTL voltage across the speaker is 85V. 85V over 8 Ohm leaves a current of 10.6A peak (below the current limit of 12A) but in 4 Ohm it becomes 21A peak, which is far above the current limit. Therefore, only 8 Ohm is recommended for BTL operation at full supply voltage.
But, we could reduce the supply voltage to +/-20Vdc in which case the peak current is 10A in 4 Ohm - well below the current limit. Or if we already have a+/-40Vdc power supply and a 4 Ohm speaker, we could change the coupling from BTL to SE in which case the peak current remains at 10A.
In both cases the maximum output power in 4 Ohm is the same, at 200W.
In the particular case with two 24Vac transformers, the BTL→SE change could be the way to go. If redundant TDA8954TH channels are then not used, the inputs to those channels should be short-circuited to signal ground and the output filter disconnected from the channel outputs.
Apart from load current limits there are other issues to worry about such as the thermal design and PCB layout for high currents. The amplifier board you link to I find aesthetic but I would worry about the result if it was left to operate at 2x420W (in 8 Ohm) for just a short period. Theoretical and practical performance can deviate a lot.
TDA8954th btL amplifierHide this!Advertise here!
Thread Tools
TDA8954TH - XH-M252 board - anyone? dzwer Class D 73 23rd February 2021 07:14 AM
Boss NXD3500 car amplifier hooked to an Onkyo 7.2ch home amplifier Evolver Class D 1 13th March 2020 10:48 AM
Hypex SMPS400 + 2x UCD180 wiring (DC error, Auto Amplifier Enable, Amplifier Standby) maxw Class D 48 26th May 2017 06:47 PM
problem with tda8954th shahpoori Class D 2 22nd May 2016 05:52 PM
Motional feedback amplifier based on Philips 40 wats amplifier 1970s sanbadgujar Solid State 14 13th October 2013 01:35 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
