1000 watt amplifier to Dayton Audio MK402?
Old 21st January 2019, 04:14 AM   #31
freddi is offline freddi  United States
freddi's Avatar
80 watts should be a good match as long as speaker isn't over driven/heated by the program material. (the woofer voice coil may be 3/4" - 1" diameter) What are you using for the power supply?
Old 21st January 2019, 06:47 AM   #32
jazbo8 is offline jazbo8
jazbo8's Avatar
@realflow100 - please do not start multiple threads for the same project, your threads have been merged.
Old 21st January 2019, 06:01 PM   #33
realflow100 is offline realflow100  United States
its 1" diameter
im using 1000 watt 12v constant current constant voltage power supply 84 amps set to 14.4v with super capacitor bank hooked up.
I dont turn it up past the point of audible distortion though. just room listening volume or a little louder if I want some more bass
with the speakers at maximum excursion with no audible distortion they are only getting around 12 watts RMS each.
1000 watt amplifier to Dayton Audio MK402?Hide this!Advertise here!
Looking to make 1000 watt Amplifier pcb board need schematic us1070 Solid State 23 24th October 2015 10:10 PM
Blazer 500/1000 watt amplifier kamranyousaf Everything Else 18 14th January 2015 03:11 PM
quasar amplifier by dr bora 1000 watt andrewlebon Solid State 90 9th December 2014 02:03 AM
THE CHAMP CBA-20807 1000 Watt Valve amplifier digits Tubes / Valves 4 26th August 2011 07:56 PM
NEW Dayton 1000 Watt Subwoofer Plate Amplifier - CHEAP! BHTX Swap Meet 0 28th December 2006 06:08 AM
Copyright ©1999-2019 diyAudio
