I am looking for a reliable strong sub amp that will power my small subwoofer. The sub is looking for 75w. Peak up to 100w.
I only need the amp to power the sub so the 2.1 style amps are not necessary. Just a single that can go to 100w.
It looks like the TPA3116 may do the trick. I found a few prebuilt on ebay, around $30.00 in the case.
I will eventually need to enclose it in a case. Clean connections.
I do have a couple of 19v 4.75a power units that could power it. Left over from notebooks I had. Is this enough power for the board?
If you guys have any other suggestions I am open! Thanks..
No matter which chip you chose - to come close to 100W with a 19V supply requires a 2 Ohm speaker.
With 4/8 Ohm you get 50/25W respectively.
What about stacking the two 19V to 38V?
A TDA7498E board configured for PBTL is a possibilty. 8 or 4 Ohm sub driver?
4ohm.
Got it..
You could do that with TPA3251 - but not feeding a TPA3116What about stacking the two 19V to 38V?
38V supply and 4 Ohm should leave good 150W.
Can't seem to find those nearby. Online or eBay?
I have this board, which I am pleased with:
Practical TDA7498E 2X160 W Double Canal Audio Amplificateur Conseil, soutien BTL Mode 1X220 W Unique Canal, DC 24 V Numerique Stereo Po dans Amplificateur de Electronique sur AliExpress.com | Alibaba Group
There are indications for turning it into a mono PBTL board.
Similar can be found on Ebay.
Another possibility is TDA8954:
Similar can also be found on Ebay.
I'm quite a fan of the 7498 series, running 7498, 7498E & a 7498MV to drive a Tannoy sub (bought cheap because the OEM plate amp had died)
Here is an example of a TDA7498MV mono amp, which should meet your requirements (subject to PSU)
Aiyima TDA7498MV Audio Amplificateur Conseil 100 W HiFi Mono Haute Puissance Amplificateur Numerique Conseil Soutien BTL Sortie Audio De Voiture Modifiee dans Amplificateur de Electronique sur AliExpress.com | Alibaba Group
I just notice my link to a TDA8954 mono amplifier was just the same link as above. It should have been:
Haute Puissance Amplificateur Numerique Conseil 420 w TDA8954TH Mono Canal Numerique Core BTL Mode fievre Classe dans Amplificateur de Electronique sur AliExpress.com | Alibaba Group
The TDA7498E mono board proposed by Yatsushiro seems very fine as well.
This is the actual version I have, similar to the one I linked to above, but with selectable/adjustable gain.
With a 19v brick supply, looks like it will be a good match for a 4ohm woofer; and, at such a cheap price, surely it's worth a try?
GHXAMP TDA7498MV Hifi Mono Conseil Amplificateur 100 w Classe D Amplificateur de Puissance Numerique Conseil DC14V 36V Pour Voiture Audio Mise A Niveau 1 pc dans Amplificateur de Electronique sur AliExpress.com | Alibaba Group
Note that the 7498MV chip is a pure mono variant of the 7498 family (datasheet here: https://www.st.com/resource/en/datasheet/tda7498mv.pdf)
Thank you. I will take a look..
Ignore that request above. I will just stick with the brick style power for now. Going to look for a reliable 24v 5a unit to make sure it has lots of room.
Where are you guys buying your 3116 boards at? There are a ton on eBay, some on Parts Express. Any particular models that are higher quality or better built from all the options out there? Thanks..
Thanks again for all the posts. Where can I find internal power supplies for these? I can build a aluminum box that would contain both. I actually prefer that to the external brick type.
Are you not going to use the two laptop "bricks"?
Alternatively something like this?
AC/DC Adaptateurs 180 w AC 100 240 V a DC 36 V 5A ac dc 50/60Hz Alimentation a decoupage Conseil Module ac dc module 36 V 5A dans AC/DC Adaptateurs de Electronique sur AliExpress.com | Alibaba Group
2018 Meilleur Vente AC DC Module D'alimentation AC 100 240 v a DC 24 v 9A Alimentation a decoupage conseil dans Circuits integres de Composants electroniques et Fournitures sur AliExpress.com | Alibaba Group
Just one should do..
Right you are, but then it is 42W in 4 Ohm with a single laptop "brick".
- Class D
- Need to find a reliable subwoofer amp, TPA3116?
