Good amp with pre out and digital input
Hello
I'm looking for a decent stereo amp with multiple digital inputs and a pre-out/main-in to connect an EQ.
The amp would feed two 4pi speakers built according to the plans of Wayne Parham (big thank you to him).
VxbHzHprMycbKs-chUPdZ4bfp_UR-v2D8Vwf-m4Hv5OHdvtyeJlziIOf9cHSVQKxffufAM-7kq9j2vH17ZiYOc7YqJSVgMM74JNoTbW-9nCisGiKIck_a3Og2xmwimOqLjerbwQ8_HQ_9J9DLWu2NZyrgqkIuC19iP-5NW8iBLIuboncsdS7xbJ6PC3MSJ1T8xvLS3_1Q0LjYUOl_x_IrXqt6ciJ39ZMFg3PcP_LbCQ3-eaBPq5QaJMH_zRjwqDBnodvyz8y66HFWP9X1NrgvGQcN19b6_II7dvx545-1VZx2zh0bLPcZ8L8GBfQg1NWbylSYvzaddXKLkc-kUf6B1GCMgP0Di4VInM1VKA8WaSTTffYEtFlbhWSdLLETjiXvIbAB5D9AjKinUh6yrgFvMEpju_8873jbFJxE9FQN6hJ2lmUQAo4IBtitTn_dIopQoq9XS39LsCMPyIIfkClEzPSxyZyQ6j3xBNnlVQYVtlveCU5QRwpn0yu_ghGCF9x-6ggJkW73Aa0BPCv23cHPycqUt2OQ52faEcOfqNfVE9sDLlGgrv7UsU0G_5KI04Xh0TMC00klpKzZBibChdToemrpGHvv8VHOxj5vN9ZCApuTaOukWXobS0OWfHpISzTqXPTVErRgBcJ3859rE1qq2pRSUxkD8rC9pF-TCNsAYVliEZmf24qdP7dEuyrRWhqHAbKMEJJA3nxJEjiY8E=w509-h340-no
Room accoustics are far from ideal. We have an L-shaped living room with lots of room modes.
2-qSIEIr0oRnLjsP3RHaFUgGH7O346sNU57EPBjkdXvf5U3jQM-At_RGbtkJDq5fMFhbgoxUUkmsdjijFbigHo2-v9ftsZIfWqeFYLpiE_W_SKsDs26R53PV9EAfALeA24w4NTS2tNWYHTfOvV2A15IkSPJEEiwfvh1eP_lL_Rs07RzBtMRraNF27nAD3Lt-o66d7aukcG0seDP8oKBGZUgDD_T4imrJs4xp4ab8cdzAZnVsjlK1D0VzOq0lscWEnzGneINQimalE6rjp-Hx61yfRczFCAa7wiNAPsDvUWLKEBxBZwroX4fn-LD8vXrzw45Cdt56iIxkJzMBn6JGkB_ZlJ_MVHGX_y-yyrENv4dM_pSFWImgncpxSNNXgp96edubvCfKixHwa5NhZ1RT1MomCYph-aXmWnmcUAYNKEY5U_GReqegijxH4EfWG_8D44YEC7dcFy6i6oABLMr3NtTS0tDy76-_ufvFdYe4JCrLHzv9ep3pcfp-CQnVP8YbX3lW0mzCk9rHi_nH0I3mEc9SWAnR6W24VuWr_LtBuSZIpTRCY2nLpvy6wEN9OqaajL4Gpo4sCy9UrDezwi5JICJaMQpgW2SDo6SCK3UvhWj1D0hPWenlPYZ6oCw699J3--OCGOvGlUxQlT_4pSI3F596ufTKEbcfCeByH2f-Ms-yC1Aw0TbmqRHcx9pW1zMGHKpsYc1uEbE8t2EKFLk=w509-h302-no
Only accoustic treatment are curtains, carpets and 2 cabinet bookcases on the opposite wall of the speakers.
ZnyusGIEr9dc34km9Wa7Fx-vTBD9fNuuVOusG5btq55095IkJLDn78ISblEGSdLsWENbjpBh_lTAj8F1tu2Mlw-cz6lTVBgBzk7BPdhyXJOghWSyYD6FUP-10OMCvAsYOyfr7neUSZ4kya77kcG8Zr-eSa62ZWICAlneXbabyEVV3hKmCHH3H5tBzqQd8rO9jfbfsfWADxh4o_1-Mqrw74XM_UWTsLkMKteI0jdyVpNQegP70wMblKG3MquHTU4XYoyttFscN5WJ11Zok0Oohw39XMxbOnrcq4EMMHB-cNnlUd-xkGer126iwoT5Hp8ksvg3nB1tZ7QJ4Y5V0KlXpNub2SKGutHKdeuKNAmOxUHnflmv2nYF-7ztf8LlaW7Ik6jjSFbj682mzFT2C4Fkrmd9p5XMGP1Umzgdkc7ponP5V1K8j58QKPF-Ha_6OMLSRPPncRg6DTZF42GlbcPnEZSR7y2A_plBOVH70Au2xw2tIYXVqnVtsh27vuVu7usvKlMDllU-kzhhOH6-KlRHrCYDZYHfLPqWVC6SUdLWSBjx6TTAKDgkdba-hTCVB1Yd0rUYoLDRSmpnhuoDfAC0wpAo3r2zyy3OS_QqfaKVaHY5K705RtLSNRAZjOUYGvQPo57pKsJMGXXPqBXHypYfyH3xVSMfjo_VsTb8Nc_i2arNY5DaJkH7LeISNBkHKS2_j_oNYvxonrrYxf9v_qI=w509-h340-no
I did a measurement with REW (listening position, no toe-in) and you can see that the low frequencies are far from ideal.
3LuQFdC_LSoZnlaWBkfDEXMkc_DWITcVeMLsYu3-x9t5oI67o59nRdhN8WQwS7jQ4Y5NN0WwKfbk1jFufAVj8ppevo5J1_b7gZXnm5NrNFD8g9_OfhzXC6zRRxlYSIUEjueV3LmXQtremRLe-c-cPiph3Oh5U-hD62KqixiJE14KIpx2VdOP2byzebmWEocCfy42ORtqQfCrpwfjxVyD1nBAXf9phaqN56m3Hj4mBC1nXfiYBh14p_w5ImuiFMH24bRnYAWwVs4koplzyXGbzVGRHvL5Ypj7QSHgsE7t6xd9xbNAZsEHl5hB_8vHCq9mpRyAKnGumDvTCdWPgSsYVZ-D9w2MAqvO-QzuUImetadysvow5cZZ7MWjLTt3WB2bqYzu5lv4WMglIRUH1jq88AafZTuXCVhJyAt6PJKMSVJFJ0DSVeow8OB9e-oMV07PcQN_Ve5U1JSiQ8qXCOgo0vW6KQNMa2tbUIaqGTV9tEbR96659O0gr6TONkkCQsWnNWsBlNL1ZLg92oJWGnRAHxkBPZPM7FzGKxdtX5y_e4eUR30zf3x0Rw9VgStUTaqfpd-NpuqhvsXHXIm_2qkpfXmw1X5nWlOFKeaH_-kL1Miqgppw23LzlrkfBvBYkRk0TAwY--lFgtcyCGCeC889sI7hdFk3Y_wbpBR2oazKQe_YyXuU5cHUPPehsCsmmYnnw5R7cZKtli4LiyhThPo=w509-h224-no
I know there is a way to smooth the low frequencies with multiple subwoofer approach, but I don't know if it works good in L-shaped rooms. And those amps and subwoofers are a big investment...
So I'd like to solve the problem temporarily with an EQ hooked up to a decent stereo amp and do some room correction in EQ. I know it's not the best solution, but for now this is what my budget allows me to do.
However, in the pricerange $500-$1000 most of the stereo amps with digital input nowadays don't seem to have pre-out and main-in?
I'm looking for a decent stereo amp with digital inputs (at least 2) and a decent built-in DAC, with pre-out/main-in (or tape-loop) connection for EQ.
Budget around 700$, so I have some $ left for EQ.
I found this french amp: X-i90 - Advance Paris
Is it any good? Or advice for other amplifiers?
Thank you very much!!
PS I have a miniDSP 2x4 laying around, is it good for fullrange EQ (mostly <300hz) or does it affect sound quality too much?
I'm not sure about ready-made amps, but i'd imagine boards using things like the TAS325x (digital-input class-D amps with some DSP integrated) might possibly be a solution?
From your description, it sounds to me like you'd basically need a multiple-input DAC, and an amplifier. The exact device that does all you'd want it to, might be tricky to find.
But hey, this is DIYaudio, not buy-ready-made-stuff-audio :D
Why not something like the miniDSP 2x4HD and a stereo amp of your choosing? the MiniDSP HD has better DAC than the original 2x4. It has Toslink, USB, and analog in. Can use a remote for volume control? Operate it as your digital preamp. It can drive a stereo amp directly. It is only $200 or $399 if you add in the Dirac live software. Get a stereo amp or possibly use your existing one.
Can you explain me more about the difference between MiniDSP EQ and Dirac EQ please?
FWIW, I found an interesting solution that could fit my needs (and maybe others): Yamaha RN803D, an integrated stereo amp with built-in room correction (YPAO) and multiple digital inputs.
It's just a pity that one can't adjust the room correction EQ-curve. It's pretty automatic.
