TDA8954TH - XH-M252 board - anyone?
Old 20th January 2019, 09:45 PM   #31
tacoman5000 is offline tacoman5000
Yes, that's what i'm trying to do
The preamp is something like this:
Amazon.com: Nobsound High Precision Passive Preamp Volume Controller VOL Control HiFi Preamplifier ALPS (RCA&HiFi Version, Black): Home Audio & Theater
I want to be able to connect the audio input of the amplifier board to the rca out of this kind of passive preamp but I don't know what to do with the ground..
EDIT: It should probably be advertised as a 'passive volume controller' since it doesn't really amplify the signal.
Old 21st January 2019, 12:13 PM   #32
dzwer is offline dzwer  Bulgaria
dzwer's Avatar
Passive volume controller - that's right!
Here is your case for stereo:
Nothing moves you like a hydropneumatic Citroen...
My Youtube channel with my concert recordings of Bulgarian bands: https://www.youtube.com/user/snejankoable/videos
Old 22nd January 2019, 01:54 AM   #33
Great, thanks for that! I will try this later when I can and report back on the results. Cheers.
Old 26th January 2019, 09:35 AM   #34
I finally got around to hooking the amp up and everything worked well
I can't really use it with my main speakers running on active crossovers yet (Fountek NeoCD3.5H + Vifa NE180W) but I tested it on my pair of Usher S-520s and they sounded good! Full and impactful, in contrast to how these speakers have a tendency to sound bright and thin with some hardness in the upper midrange with some equipment. I did not get this sound with this amp at all.
There is a slight hum on both channels that is audible when you put your ear really close to the drivers, but inaudible even less than a meter away. The heatsink gets rather warm in 24V operation but even a very slight breeze from a distant fan is adequate to keep it manageable.
Other than these, everything's good. I look forward to getting this setup fitted in a proper case.
Old 20th February 2019, 05:09 PM   #35
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
What do you guys think of this one?
New 420W *2 Large Power TDA8954TH AD Digital Audio Amplifier Board Dual AC 24V | eBay
$36 built and shipped just needs a 28vac 400VA trafo and can do 200w into 4ohms. Sounds unreal - but maybe someone here has really pushed these to the 200w limit?
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 21st February 2019, 06:33 AM   #36
dzwer's Avatar
There is a switch mode DC-DC convertor for the fans - it may introduce noise in the sound...
Also the noise of the fans...
The only one positive thing is that the output inductors are actively cooled by the air from the fans.
TDA8954TH - XH-M252 board - anyone?Hide this!Advertise here!
My Cambridge 500SE, needs an output board (to replace internal DAC Board) slbender Digital Source 1 11th July 2018 02:43 AM
Unknown Board DC12V TPA3116 amplifier board DIY L163-9 AUS Ben Class D 0 8th December 2016 04:05 AM
Wanted: LM1036 tone board (no ebay or aliexpress board) schdrag Swap Meet 0 2nd December 2016 06:47 PM
problem with tda8954th shahpoori Class D 2 22nd May 2016 05:52 PM
HIFI 700W Subwoofer Mono Amplifier Board By 10 Pairs 1943/5200 Amp Board For Subwoofe nelnar Solid State 2 21st July 2014 06:35 PM
Copyright ©1999-2019 diyAudio
