Bi amping set up for active 2 way TPA3116
I am just finishing the wiring up of a pair of two way active speakers using a minidsp 2x4. I have two stereo TPA3116 boards which are NOT going to be located inside the speakers, but in a separate enclosure.
My question is: Is it better to use one board for the woofers and one board for the mid-tweeters, or to use one board for the left speaker and one board for the right speaker?
Thanks.
Use one board for the left speaker and one board for the right speaker.
Low frequencies need more energy and the board for the woofers will produce more heat.
Also, when use one board per speaker, there will be no stereo crosstalk.
I have the same setup - ADAU1701 + 2 stereo boards with TPA3116 + 2 Panasonic speakers.
