LTspice Ncore simulation
Old 3rd October 2018, 06:28 PM   #11
Reactance is offline Reactance  South Africa
Reactance's Avatar
Interesting seems like alot of reverse engineering effort, missing bus rail bead inductors.
There’s nothing worse than the smell of burned output transistors!!
Old 3rd October 2018, 06:29 PM   #12
irs20957 is offline irs20957  Russian Federation
simplified a little for simulate, i have full scheme
Old 3rd October 2018, 07:09 PM   #13
luka is offline luka  Slovenia
luka's Avatar
Originally Posted by analogspiceman View Post
I have created a 5-pole, 4-zero (I think - haven't derived the transfer function yet) network that reproduces the magnitude loop-gain curve in the white paper. The phase response curve is not published (at least I haven't seen it)
YouTube
from 19:20 onwards
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 4th October 2018, 01:46 AM   #14
analogspiceman is offline analogspiceman  United States
I looked at Ncore section in the NAD M22 service manual. It seems to use a twin tee active filter for the low frequency pole pair and the output L-C for the 3x higher frequency pole pair. Everything is fully differential so it is more difficult to follow. Also much of the circuitry is just a discrete fast comparator that drives the output MOSFETs.
For the purpose of analysis, understanding and system simulation the output can be replaced with a simple behavioral power comparator with settable delay and the feedback and analog front end may converted to a single ended equivalent. The saturation protection can be behaviorally simplified as well. If correctly done, the result should simulate correctly both in the frequency and time domains.
Old 4th October 2018, 04:00 AM   #15
kASD is offline kASD
kASD's Avatar
Yet another similar approach using twin T networks
Old 5th October 2018, 01:55 AM   #16
Okay, I have simplified and reduced the NAD M22 Ncore fully differential design to its single-ended equivalent. The output stage (which is just a fast power comparator) has been replaced with a behavioral subcircuit. The front-end opamp (also a behavioral model) is driven single ended but it has complimentary outputs in order to achieve proper phasing in the feedback loop.
The behavioral model of the output includes a stimulus source to enable measurement of loop-gain (which then is measured at the comparator input fb node).
Self-oscillation at the undesired lower frequency is suppressed with a bidirectional behavioral diode (its clamping parameters are adjustable).
Because it is cut down to the bare essentials, the simulation runs very fast. It probably could run even a little faster by removing the linear time delay element required for the ac analysis (it would be replaced by a simple a-device delay).
The feedback network around the opamp is not really a twin-tee. In the original circuit it is a dual differential balanced low pass tee (two tees, but not twins in the usual sense).
Old 5th October 2018, 04:00 AM   #17
luka's Avatar
peak gain is a bit too high, should be about 65-66dB, as is where double zero act, there should be about 10dB, apart from that, it looks just like the real thing
I FEEL SLOVENIA
Old 5th October 2018, 04:15 AM   #18
I haven't analyzed the influence of R1-R3, C1. It must tweak the closed loop transfer function a bit. I wonder why they are there. Maybe they help to linearize the open loop transfer function.
Old 5th October 2018, 07:13 PM   #19
Reactance's Avatar
Have you looked at the patent I think vie seen it described in the UcD patent.
Old 5th October 2018, 07:30 PM   #20
I made a small mistake in the conversion to a single ended topology. The value for C1 should be 4n7 rather than 1n0. Please correct this in your simulation schematic.
LTspice Ncore simulationHide this!Advertise here!
How to do IMD simulation in LTspice!!! nicholas1113 Solid State 40 23rd February 2017 04:51 PM
NTC thermistor LTSpice simulation danny92 Software Tools 4 28th November 2013 04:00 AM
LTspice simulation 8409513 Power Supplies 2 28th May 2012 03:02 PM
About LTSpice Simulation. nicholas1113 Solid State 2 15th November 2009 07:52 AM
LTSpice Simulation template?! ipop07 Software Tools 5 13th May 2009 06:17 PM
Copyright ©1999-2019 diyAudio
