Wondom/Sure AB32155 hiss
Old 24th September 2018, 04:47 AM   #1
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Default Wondom/Sure AB32155 hiss
The AA-AB32155V00 I bought has considerable hiss that can easily be heard 1m away. Sure-Electronics kindly sent a second module that that was no better even though they said it would be tested prior to despatch.
Sure Electronics' webstore 2 x 15 Watt 4 Ohm Class D Audio Amplifier Board - TA2024
I've used several TA2024 modules and amps before such as Sonic Impact, Dayton DTA-1 and Dayton DTA-2 which were very quiet. I've also got a TPA3116D2 (black blue module) which is very quiet as well.
Have other users of this module noticed this hiss and is there anything that can be done prior to the signal input or or after the speaker output that could help. I've tried different power supplies, leads, speakers, sources with no change in hiss. I don't want to play with the module as my eyes and hands are not up to it.
No longer DIY active
Old 24th September 2018, 05:19 AM   #2
FauxFrench is offline FauxFrench  France
I have another TA2024 module and it is silent. TPA3116 is known to have hiss if the source impedance is too high.
If you remove the source and short-circuit the two input lines to ground through 1KOhm and you still have hiss, I believe it is inherent in the board design and you cannot do much without having to modify the board.
Old 25th September 2018, 07:30 AM   #3
rabbitz's Avatar
Thanks. I'll try that this week end.
Old 29th September 2018, 05:56 AM   #4
rabbitz's Avatar
Tried the 1K resistors to ground and hiss is still the same. Binned the modules.
Wondom/Sure AB32155 hissHide this!Advertise here!
Experience with Wondom Sure DSP Colakurt Digital Line Level 4 10th August 2018 03:23 PM
Bi amping with a pair of Wondom amps? DaveFred Chip Amps 8 3rd July 2018 11:45 PM
diy amp using sure electronics(WONDOM) Amplifier Boards CorysCustomInstalls Car Audio 3 22nd October 2017 08:48 AM
TPA3116 4.1 + Bluetooth (4x50w + 1x100w), to Hiss... or not to Hiss yakelkun Class D 0 25th March 2017 04:02 PM
TA2024 AA-AB32155 gain regulation iggyboy Class D 0 24th April 2013 09:02 AM
