TPA3116 D2 mono amplifier as a stereo system?
Old 23rd September 2018, 08:59 PM   #21
AudioMech73 is offline AudioMech73
So it would be possible to use a NE5532 Stereo Pre-amp board like this in order to volume control the 2 mono amps (in stereo) and connect a single source via the audio input on the pre-amp?
Trying to wrap my head around the exact cabling...
https://ae01.alicdn.com/kf/HTB1Sm_vg...bq6AwxVXaF.jpg
https://ae01.alicdn.com/kf/HTB1bLhHQ...Xq6xXFXXXv.jpg
Old 23rd September 2018, 09:11 PM   #22
FauxFrench is offline FauxFrench  France
It can do the job. Very attractive price.
The output cable is not the most easy to work with.
An alternative avoiding the small output connector but more expensive: Aiyima NE5532 Ton Preampli Conseil OP AMP HIFI Amplificateur Preamplificateur Volume Tone Control Board dans Amplificateur de Electronique sur AliExpress.com | Alibaba Group
NE5532 HIFI Preampli amplificateur pre niveau ton conseil avec Aigus milieu de gamme basse controle du volume dans Amplificateur de Electronique sur AliExpress.com | Alibaba Group
The amplifiers have to be set to non-balanced mode such that you use ground and only one input line.
The pre-amp has a ground line and two signal lines.
The pre-amp ground line goes to the ground inputs of each amplifier module.
One signal line from the pre-amp goes to the input line of the first amplifier.
The other signal line from the pre-amp goes to the input line of the second amplifier.
Just get your head back in place....
I just ordered one of these TPA3116 modules as well. Only one, just for test. I have too many other already.
Who gets his first?
Old 23rd September 2018, 09:42 PM   #23
Or, this one: NE5532 HIFI Preampli Preamplificateur Conseil 2 Canal 4 Tune Types OP AMP Volume Tone Controle EQ Conseil Module Mayitr dans Amplificateur de Electronique sur AliExpress.com | Alibaba Group
Old 23rd September 2018, 09:50 PM   #24
Head back in order...
I am sure your shipment will be quicker; local customs is a pain...
There are a couple of interesting pre-amp alternatives with the same chip:
YuanJing Dezhou NE5532
TIANCOOLKEI NE5532 / AD828
Effectively, I only need a master volume control and the source input. Not sure if there are also version that stream Bluetooth...
Most of these pre-amps seem to serve 10 watts per channel. That would not impact the main mono amps, right?
Old 24th September 2018, 05:49 AM   #25
Our reception time is random. Sometime surprisingly fast, sometime 2 months.
The first board looks fine, no small connectors.
Bluetooth receivers with a volume control exist but are expensive and probably without an aux input:
NEW SMSL B1 CS8406 CZZ MAX97220A Digital Hifi Bluetooth CSR 4.2 Audio AMPLIFIER Receiver Decoder Bluetooth APT X-in Headphone Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
It is not that the pre-amp controls directly how much output power you get. A pre-amp has a sensitivity on the input and can output a rather high impedance signal with a certain amplitude.
The amplitude at the pre-amp output together with the gain of the power amplifier determines how much output power you will have.
Unfortunately, there are no standards which are complied with such that you are certain you can use the full power of the power amplifier or you don't get too much output power with the volume potentiometer turned towards left. You may have to adapt the gain.
Old 24th September 2018, 01:11 PM   #26
Bluetooth is a nice feature but not really required.
I heard good things about the YuanJing boards; the only disadvantage is that it comes without mounting holes.
A couple of other alternatives:
HIFI College JRC5532DD * 2 preamplifier board
Aiyima Dual OP Amp NE5532 Preamp
Music Fax A1 Dual op amp NE5532 Preamp
Not sure if these pre-amps are made for specific power amplifier chips...
Also, the pre-amp should be decoupled from the main system and use it's own power supply, right?
Old 24th September 2018, 01:25 PM   #27
linuxfan is offline linuxfan  Australia
I make two points about this:
i) it appears that all of the NE5532 preamps listed above have a single input - and that's fine - but be aware there's no multi-input facility.
ii) if all you want is a master volume control, I suggest what most others here have done with TPA3110/3118/3116 amps - just wire up a 10k potentiometer at the input. The wiring is simple, and with a stereo potentiometer it makes no difference if you wire to a single stereo amp, or dual mono amps.
But there is still merit in using a pre-amp; unlike a raw potentiometer, it buffers the input and maintains a consistent output impedance regardless of volume setting, which is good for the amp.
And if you go to the trouble and expense of buying/installing/wiring a pre-amp, you might as well get one which sounds good with your amp!!
You may have read on this forum that the TPA311x amps sound very detailed, but a touch "cold". Many of the early testers here, and on other forums such as audiocircle, said that adding a tube preamp to the TPA3116 gives a great overall sound, and the popular tube preamp to use is the "Matisse circuit" with 2x 6N3 tubes -
6N3 Tube Amplifier Preamp AMP Pre-Amplifier Amp Board Kit + Transformer | eBay
It's just under US$40.
I see you only have a pair of small cube speakers at the moment, but once you upgrade your speakers you are more likely to appreciate the difference.
Old 24th September 2018, 03:52 PM   #28
A tube pre-amp looks like an interesting option.
International shipping costs are a bit crazy on ebay.
Are you able to recommend a board from Aliexpress @linuxfan?
There seem to be a couple of 6N3 options available (no purchases and reviews though):
6N3 Tube Amplifier Preamp ( Reference Mattis Circuit)
6N3 tube preamp board (with tube Rectifier)
GZLOZONE Assembled 6N3 Tube Buffer Preamplifier Board
Assembled 6N3 Tube Buffer Amp Audio preamp board
Not sure what the tube quality is like...
Old 24th September 2018, 04:22 PM   #29
Here's the original Matisse 6N3 layout, board+tubes+transformer for $44, or fully cased for $86 -
2018 6N3 6H3N bile preamps Matisse HIFI tube fever bile preamplifier preamplifier -in Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
The first link that you provided appears to be an updated (and larger) version of the Matisse circuit. Might be better? Be aware it requires two AC transformers, not supplied.
Probably not great, but just try the supplied tubes at the beginning, do a listening test using the preamp, versus going straight to the TPA3116. If you like the sound of the preamp, then consider upgrading the tubes. My notes say that a nice (and affordable) tube upgrade is the Russian 6N3P-EV, and maybe even better - Tung Sol 5670. At this point, you should talk to the expert in this area - forum member Poultrygeist.
Old 24th September 2018, 07:09 PM   #30
The Matisse model you suggest gets excellent ratings for the price point and the Russian tube replacements are really cheap.
However, 90$ for a pre-amp is a bit over my budget at the moment and I cannot find any reviews on the alternative Matisse 6N3 boards that I posted, which could be a bit of a gamble. The reviews on the cheaper 6J1 tube pre-amp suggest that the sound does not really improve a lot and you won't get that typical "warm" sound.
So I guess I will have to stick with a NE5532 for the moment and upgrade later...
TPA3116 D2 mono amplifier as a stereo system?Hide this!Advertise here!
zenith console amplifier (a stereo mono amplifier :) ) dr_skoobie Tubes / Valves 1 14th February 2015 03:42 PM
SMPS for Stereo Amplifier vs Mono Amplifier eem2am Power Supplies 0 7th December 2011 05:36 PM
Bridge an stereo amplifier to MONO Mikewong Solid State 3 27th July 2011 02:57 PM
Mono subwoofer on stereo amplifier possible? Audio Johnny Subwoofers 9 21st April 2008 10:31 PM
PA System Stereo or Mono 96tahoe PA Systems 8 4th April 2008 11:33 PM
Copyright ©1999-2019 diyAudio
