TPA3116 2.1 Channel BT - Sound cutting every 1s @ low input (video)
Old 25th September 2018, 05:52 AM   #11
FauxFrench is offline FauxFrench  France
Originally Posted by eljoantonyn View Post
OFFTOPIC:
I have the exact amp board (bought from the Aiyima storefront at Aliexpress) and noticed the capacitors at the power supply side are low voltage (only 36V). Is that OK ?
The voltage rating of 36V (35V is normal standard) is fine. TPA3116 can handle 26V maximum.
Old 25th September 2018, 06:40 AM   #12
eljoantonyn is offline eljoantonyn  India
Ok, thanks for the reply.
Old 25th September 2018, 10:35 PM   #13
Think is offline Think  Netherlands
Originally Posted by overdose View Post
thanks for the advice.
Yeah, I use it for 3 months in my diy box, and it was ok.
Suddenly, volume @ 15%, the sound start clicking like so : YouTube
I did some test on many speaker, and figured out that the right channel was clicking hard (DC to speaker), left channel was turning the sound off, and subwoofer still running.
5 first minutes @15%, the sound is ok. After the 5 minutes or so I need to put volume @50-60% to avoid cut-off. And 50% on those amp is loud.
I was under the impression it never worked correctly, so something on the board is probably damaged; as it functioned OK before.
Old 27th September 2018, 02:24 PM   #14
overdose is offline overdose
fauxfrench put me on a good track.
Those amps are shipped in a bubble wrap, poorly protected.
One capacitor might be in fact damaged.
I watched your video. I only see one speaker. Is that the left channel repeatedly turning off the sound? If yes, there is also a right channel (with DC failure) we don't see and a sub-channel we don't see?.
DC at the output could be caused by a leaking coupling capacitor at the TPA3116 input (right channel). When the right channel puts DC on the speaker, it does not take long before the safety-circuit shuts down the whole chip and after about a second, attempts a "hick-up" re-start which turns the left channel on for a short moment.
Perhaps the key to the problem is the right channel that only does "clicking" (no music), correct?
you wont see anything with those small cheap speaker. Its noticable on the 12''
- right click and stop music
- left only stop music
- sub still running fine
the ''sub'' 6.5'' is on the back .
See the inside, with a new smaller chip. Sound is better with this chip, but 50wx2 isnt very loud...
Old 27th September 2018, 08:01 PM   #15
Thanks for the photos.
Try to start the system with music as usual and with a voltmeter (DC range) across the right speaker terminals. For a start the voltmeter is likely to flicker somewhat from the AC music but without a clear DC component. After a while, you will probably see a DC value grow until you have the clicking in the speaker. Then switch off.
TPA3116 2.1 Channel BT - Sound cutting every 1s @ low input (video)Hide this!Advertise here!
Search device (sound card ?) with HDMI input, video passthrough, gug42 PC Based 2 26th July 2018 12:30 AM
TPA3116 Cutting Out miwin Class D 6 19th December 2016 04:00 PM
4.1 TPA3116 hiss *video included* tigox Class D 3 21st June 2015 04:58 PM
Sony TA-VE215 cracking sound/sound cutting out crowdome Solid State 4 2nd October 2012 03:39 PM
