Hypex Fusion bug and wishlist
Old 29th January 2019, 09:45 AM   #71
pos is offline pos  Europe
pos's Avatar
Originally Posted by DannerD3H View Post
Why does the frequency graph not go down to 0 Hz?
There is no such thing as 0Hz in a log scale
2019-01-16: rePhase 1.4.3
Old 29th January 2019, 10:00 AM   #72
DannerD3H is offline DannerD3H  Denmark
Okay then just 1 then :P
Old 29th January 2019, 10:49 AM   #73
paalj is offline paalj  Norway
+1 I have a HP filter @ 5Hz that I cannot edit. Most of IT is not visible in HFD so I have to measure on amp output.
Old 6th February 2019, 08:43 AM   #74
Leliks is offline Leliks
My experience of updating to v1.3 firmware of two FA253. First one was flawless. Second one got "not in bootloader" error and i had to restart it, then it went ok.
Old 16th February 2019, 08:20 PM   #75
gnl is offline gnl
For my FA123's this firmware upgrade resulted in a significant output level increase of the NC100HF relative to the output level of the NC122MP channels. The configuration files had to be modified to compensate for this.
The release notes of the v1.3 firmware mention:
- Gain correction: when maximum input level is aplied to XLR (6.15Vrms) or RCA (2.18Vrms) or SUB (50Vrms) or digital (0dB), the DAC will drive the connected amplifier to its maximum power in 8Ohm load
The output level increase will be different for other FAxx3 models, so you may want to check the frequency responses of your system after the upgrade with the v1.3 firmware.
In the case that you use a combination of FusionAmps with different output powers you may get similar issues after this firmware upgrade.
Old 22nd February 2019, 04:55 PM   #76
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
^Yep, with Fw 1.3 I noticed roughly 6dB increase in tweeter spl level, board FA123.
New gain settings helped to get 3dB more "sensitivity" because I used some of the added gain to heavier eq of the tweeter.
Update went easily for both units. I forgot to check if power management settings had changed with update.
Radikal aktivist AINOgradient speaker project
Old 22nd February 2019, 06:53 PM   #77
cowanaudio is offline cowanaudio  Australia
cowanaudio's Avatar
I've inadvertently created an 85Khz filter that I can't edit. It's broad and effects response at 10Khz.
Don't Procrastinate....Just Do It!
Old 22nd February 2019, 07:55 PM   #78
Juhazi's Avatar
^I have had similar problems too.
It is wise to save a working preset with a different name to serve as backup copy. Then you don't have to start again with an empty table.
Old 22nd February 2019, 08:46 PM   #79
Fenalaar is offline Fenalaar  Norway
Default Measurements in HFD
I’d very much like a start/stop frequency control on the measurement function in HFD.
When measuring tweeters, it would be really handy to be able to set the sweep to start at say 700Hz, to avoid blowing the driver.
A workaround is to add a highpass filter before measuring, but having a starting frequency setting would be a better option.
Johan-Kr
Old 24th March 2019, 02:51 PM   #80
Is there any roadmap for furhter updates and features? What team is working now?
Hypex Fusion bug and wishlistHide this!Advertise here!
The New Hypex Fusion Plate amps bavmike Class D 1335 16th April 2019 09:26 AM
Wishlist: Op Amp Characterization Curves in Datasheets johnc124 Analog Line Level 16 7th January 2015 01:46 PM
Features Wishlist Aucosticraft Forum Problems 4 31st March 2011 07:27 AM
Mr. Pass, do you have a wishlist? ssmith Pass Labs 37 27th June 2007 04:20 AM
Copyright ©1999-2019 diyAudio
