Hypex Fusion bug and wishlist
Old 31st October 2018, 07:28 PM   #51
tommus is offline tommus  United States
I posted this some time before (and will refrain from future spamming) but I think it's very important:
Global Input EQ
I am using an FA503 in a portable PA top with analog input, and without input EQ there is no easy way to apply a house curve to a flat "reference" filter setting.
Anyone else think this is a big deal?
Thanks again,
Tom
Old 31st October 2018, 10:20 PM   #52
cowanaudio is offline cowanaudio  Australia
cowanaudio's Avatar
I'd like to see the global input eq as well. I like to tame the speaker in the output channels and tame the room and apply house curves in the input channels. Locking output channel adjustments but leaving the input channels adjustable by the system installer would help too.
Also when using the internal measuring capability the graphs are unwieldy. It should be possible to individually view each channel with and without eq and view the eq applied, then view a sum plot of selected channels. Phase/GD plots would be great too.
Also I hit the delay ceiling on a horn based system I designed recently and was not able to achieve time alignment.
The Fusion amps are a few small steps away from being an absolutely superb product.
Well done.
William Cowan
Don't Procrastinate....Just Do It!
Old 3rd November 2018, 05:46 PM   #53
Flaesh is offline Flaesh  Russian Federation
Flaesh's Avatar
What delay is available in Fusions?
flesh flash flush
Old 4th November 2018, 01:08 AM   #54
smennen is offline smennen  United States
Does anyone have any information on when the first firmware update for the Fusion Amps will be available?
Old 4th November 2018, 04:07 AM   #55
cowanaudio's Avatar
From memory it was 10mS. This system used a 4.5M long bass horn.
Most users will find the available delay is enough except when they are trying to delay main speakers and separate subwoofers in their room. I like nearfield subs and would strike this problem using them in many rooms too.
Old 9th November 2018, 08:50 PM   #56
Flaesh's Avatar
"Maximum delay:
19,2ms per amplifier"
http://www.troelsgravesen.dk/18TH/Fusion.pdf p. 16
But "This user guide is preliminary"
flesh flash flush
Old 9th November 2018, 08:57 PM   #57
cowanaudio's Avatar
Either the amp I was using was faulty or that 19.2mS figure is incorrect. That would have been plenty of delay for what I was doing.
Old 13th November 2018, 02:00 PM   #58
rspam is offline rspam  Germany
1+
Global Input EQ
Thanks again,
Tom
Old 17th November 2018, 04:54 PM   #59
Bingo1337 is offline Bingo1337  Europe
It would be also nice if hypex can implement something like a dynamic EQ at least for one or two parametric filters to adjust it's boost level depending on how much input signal the amps get or till the soft clipper sets in. So for example you can tune your CB loudspeaker really low and when you turn it up your dynamic eq kicks in and lower the boost.
Old 18th November 2018, 03:15 PM   #60
Kim Bay Smidt is offline Kim Bay Smidt  Denmark
Kim Bay Smidt's Avatar
I found a few bugs:
1. Doing measurements with only channel 3 enabled, the Hypex Filter Designer (HFD v4.71) sends the measurement signal to channel 1 instead of channel 3 (FUSIONAMP FA503, FW v1.1)
2. File/project info 'Last change' isn't updated when saving updates to a project. It seems HFD shows the creation date and time all the time.
3. 'Use the middle mouse button (or press the mouse-wheel) and draw a rectangular box around the part you want to show'... Very unintuitive to use the middle mouse button for that... please change it to use the left mouse button and Mac users running Windows in Parallels will also be happy... ;-)
Hypex Fusion bug and wishlistHide this!Advertise here!
The New Hypex Fusion Plate amps bavmike Class D 1337 Today 03:38 PM
Wishlist: Op Amp Characterization Curves in Datasheets johnc124 Analog Line Level 16 7th January 2015 01:46 PM
Features Wishlist Aucosticraft Forum Problems 4 31st March 2011 07:27 AM
Mr. Pass, do you have a wishlist? ssmith Pass Labs 37 27th June 2007 04:20 AM
Copyright ©1999-2019 diyAudio
