Hypex Fusion bug and wishlist
Old 9th September 2018, 07:23 AM   #21
emil66 is offline emil66
Originally Posted by paalj View Post
I really need a volume display.
+1
Old 9th September 2018, 07:32 AM   #22
I'm still building the boxes and speaking theoretically... As I understood in the manual there is a need to upload the filter to all used inputs separately on both (master and slave) modules. If it is true why is it so complicated? I think it will be better for most of the builders to upload one "default" filter to all inputs. But, if you need a different filter for different inputs that you can change them.
Old 9th September 2018, 08:17 AM   #23
ds23man is offline ds23man  Netherlands
ds23man's Avatar
Not correct, you have to upload filters to all (3) presets.
Old 9th September 2018, 08:24 AM   #24
ds23man's Avatar
1. In HFD indicators for each limitter.
2. Input EQ
Old 17th September 2018, 12:06 AM   #25
Bingo1337 is offline Bingo1337  Europe
I haven't checked the pins and plugs etc. of the dlcp yet, but an easy way to programm the ADAU DSP by yourself via Sigma Studio or something similar would be nice to have. Then we can use FIR and own Biquads and so on. A "Standard Setup" for everything routed correctly would also help a lot.
Old 17th September 2018, 08:12 AM   #26
_jan_ is offline _jan_  Germany
I would like to work in HFD with two Fusion amps at the same time. This means that both amps have to be connected to the PC and are controlled by HFD simultaneously. This feature is a must for fine tuning of every stereo speaker setup. Doing changes on one amp and after that copying to the other is annoying.
From the software point of view it should be possible! You can use master/slave scheme. You start to setup the master and after that master and slave are kept synchronized in the background.
Jan.
Old 17th September 2018, 01:07 PM   #27
fred sonnen is offline fred sonnen  Germany
Interchangeable Op Amps to change the " sound"
Sparkos Labs SS3602 or Sonic Imagery 994 for example
Old 17th September 2018, 07:18 PM   #28
jmansion is offline jmansion  United Kingdom
I suppose an ability to group-buy from the Hypex Electronics B.V. would be nice.
Then maybe ghentaudio could supply enclosures for a 3-way amd and DLCP and not have to go with the NC400 solution - it might be nice but its too expensive for me.
Old 17th September 2018, 08:53 PM   #29
hugo stiglitz is offline hugo stiglitz  Germany
+1
Old 17th September 2018, 09:04 PM   #30
+1
Hypex Fusion bug and wishlistHide this!Advertise here!
The New Hypex Fusion Plate amps bavmike Class D 1097 17th December 2018 04:44 PM
Wishlist: Op Amp Characterization Curves in Datasheets johnc124 Analog Line Level 16 7th January 2015 02:46 PM
Features Wishlist Aucosticraft Forum Problems 4 31st March 2011 08:27 AM
Mr. Pass, do you have a wishlist? ssmith Pass Labs 37 27th June 2007 05:20 AM
