NAD C390DD (C 390DD) does not power on failure with fix
Old 14th June 2019, 01:42 PM   #11
Jabbejokker is offline Jabbejokker
Originally Posted by WimJanse View Post
@ergo
Thanks a million for this, I'm suffering with this problem for a year now.
The C390DD went for a repair last year, but problem was never resolved.
Sometimes the C390DD boots up in one go, sometimes I have to retry for a few times (2-10) before the C390DD starts up.
I'll order the capacitors right now, will do a replace somewhere next week.
Thanks again,
Wim
How do you know which caps to use? Is the part number written on them?
Old 14th June 2019, 01:51 PM   #12
WimJanse is offline WimJanse
Look at the top of this post, it gives the schematics, pcb layout and caps particulars in the first posting by ergo
Old 14th June 2019, 02:22 PM   #13
Where is the part number? Will any capacitor of same size and value work or should I get the specific type? I’m thinking maybe temperature tolerances or “grades” may differ. Forgive my ignorance.
Old 14th June 2019, 02:39 PM   #14
Khron is offline Khron  Finland
Send a message via AIM to Khron Send a message via MSN to Khron Send a message via Yahoo to Khron
You'll want "low-ESR" ones, and preferably from a Japanese brand (Panasonic/Matsushita, Elna, Rubycon, Nichicon, United ChemiCon).
For "future-proofing", i'd also replace C217 and maybe C213.
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
Old 14th June 2019, 02:41 PM   #15
Thank you!
Old 14th June 2019, 02:50 PM   #16
From the parts-list
Alu Electrolytic Capacitor
CD263(X), 1000uF, 25V, ±20%
C210 C211
100uF, 25V, ±20%,105 degrees
C204 C205
Be award, the pcb is two sided, soldered throug and through
Hope this helps
Old 14th June 2019, 10:31 PM   #17
From the parts-list
C210 C211
C204 C205
Hope this helps
What you does the cd263(x) mean? I bought these. Are they the right ones?
https://www.mouser.com/datasheet/2/3...60-1391675.pdf
Old 14th June 2019, 11:36 PM   #18
"CD263" kinda-sorta reminds me of markings i've seen on some no-name electrolytics in several cheap devices.
Those Panasonic FP's should do the job nicely, though.
Edit: Might've found something about CD263(X).
http://www.jianghaius.com/PDF/CD263-1.pdf
http://www.jianghaius.com/PDF/CD263-2.pdf
Dunno about you, but i'd take all those specs with a bucketload of salt...
Old 15th June 2019, 05:41 AM   #19
@jabbejokker
Same as I bought, panasonic elco’s
Old 15th June 2019, 11:01 PM   #20
Ok sounds good. So don’t worry about CD263?
NAD C390DD (C 390DD) does not power on failure with fixHide this!Advertise here!
Yamaha Amp RX-V 2700 Power Failure Janaka a Parts 1 13th August 2018 02:34 PM
Any full digital amp project(s) that may rival NAD C390DD? riotubes Class D 42 20th April 2016 03:00 PM
Hlly T-Amp 90 Power Supply Failure paulflowe Class D 30 13th June 2010 02:21 PM
Cyrus Power failure - help? rotebailer Solid State 4 13th April 2009 09:28 PM
Copyright ©1999-2019 diyAudio
