[design log] Neat 2x170W I2S in, I2C controlled, integrated DSP amp (TAS3251)
Old 15th January 2019, 11:50 AM   #111
doctormord is offline doctormord  Germany
doctormord's Avatar
So I understand that, as a basic rule of thumb, the higher the swithching frequency, the better. Provided that the PCB layout is not wrong.
Not in general, it depends on voltage differential, load current and efficiency goal.
The point here is to push the switching frequency of the voltage converter away from the switching frequency (and their harmonics) of the amplifier to avoid "beat-tones" which may occur as a subharmonic oscillation product between these two frequencies.
I.e. When amp is running at 600kHz and your SMPS is at 605kHz, beat-tones at 5kHz (and their harmonics) may occur. As frequency of both always shifts a bit due to temperature and load current, it's not only a single tone but something like a "weeping noise". This is an example but effects are not limited to just that.
Another issue is with light loads when the " intelligent" device may adjust its frequency. Hence the interest in our applications of Constant on Time devices.
Right, avoid frequency foldback and burst-mode. COT is prefered/needed if flybuck is going to be used to generate a second output voltage. The other controllers are fine if "possible issues" keeped in mind and the converter is calculated/layed out right.
Last , I'm not clear if there are drawbacks to go directly to 12V with the MP2459 or LMR16006 and skipping the LM2940 (compared to the EVM design that goes to 15V and then use a MP2940 to build the 12V)?
When using a relatively high converter switchinh frequency, the following LDO can be ommited as their is most likely no benefit on filtering. (Just have a look into the datasheet of the LDO to see their PSRR/CMRR at switching frequency. Pretty much all don't do much at frequencies above 100-200kHz) Filtering with simple RC or LC filter is more effective.
The EVM converter is running at rougly 66kHz. (Calculated from LM5010 datasheet equation 7, page 11 with known Ron=182kOhm from TAS3251EVM schematic)
LM5010: http://www.ti.com/lit/ds/symlink/lm5010a.pdf
TAS3251EVM:http://www.ti.com/lit/ug/slau757b/slau757b.pdf
Old 15th January 2019, 06:48 PM   #112
JMF11 is offline JMF11  France
Oups, busy time. I'll take time to read all this carefully.
Maybe I'm too cautious about hand soldering the LM5010 ? Could be easier than I think?
Best regards,
JMF
Old 15th January 2019, 07:20 PM   #113
doctormord's Avatar
I'd recommend getting one of the "cheap" reflow stations for those kinds of ICs, makes repair easier as well.
If you're on a budget, get a 858D:
Neu SMD Heißluftlötstation Digital Rework Station Lötstation + 3 Nozzles 858D | eBay
If you want an "okay" soldering iron combined into this, get a 898D:
SMD 898D+ Digital Rework Station Heißluftlötstation Heißluft Entlötkolben W.E.P | eBay
I have the latter, they are okay for the money and handy for repairs and all kind of heat shrinking. The soldering iron is at about 40W, with simple bang-bang-control. Not to bad. Basically it's the same as the older 938 Aoyue types of soldering iron skillet. I use two 938 since about 15years now.
Just make sure their earth-connection is working and low resistance.
Old 16th January 2019, 07:37 PM   #114
Thanks for the links. We have such things at the Fablab. But is is not clear to me how to use those to solder the LM5010 bottom pad. I'm sorry for this basic question that shows my ignorance. But I'm willing to learn.
Is it something like this YouTube
Or something like YouTube ?
Are you using solder paste / stencil ?
JMF
Old 17th January 2019, 05:22 AM   #115
I see that some of the designs developped here have commercial intentions. I don't have. Moreover, due to my lack of knowledge in some areas, I need collaboration to succeed having something working. But I don't see a lot of open designs here (gerbers at the most)
Question: do you think that going "fully open source" and sharing KiCAD source files would help ?
Is there a risk that experienced contributors may step back fearing to see their advices and contributions injected in easily accessible files ?
I don't think that what I do is rocket science, but I would like to go in a direction that maximizes contributions.
JMF
Old 17th January 2019, 06:00 AM   #116
lutkeveld is offline lutkeveld
I would certainly contribute. The problems I see:
-How to make a final design decision in a group of contributers?
-How to work in a shared folder with the possibility of multiple people editing the same file? Or how would people contribute?
-Who is taking the risk for final production?
Old 17th January 2019, 06:17 AM   #117
doctormord's Avatar
JMF, it's like shown in the videos, that way you may solder the LM5010.
For the point about sharing your project files, another option is, that you see your efforts done all the way finally in a product from China. Been there, done that.
Btw. people with commercial interest mostly give the least contribution in detail at design phase. (personal experience)
Old 17th January 2019, 07:10 AM   #118
My idea was more basic. Like the TI EVM that people can have details about and start from, build upon.
It seems to me that we may all have different constraints, habits, understandings... So converging to a unique design that suits all has high probabilities to fail.
So it was more about allowing project "forks" based on shared work.
JMF
Old 17th January 2019, 07:18 AM   #119
Yes, I understand this. As I don't have commercial interest for this project, my preferred option would be for it to be open to the community. Even OK for me for Chinese cloning if it derives in good product that I can buy for cheaper than I can make it by hand.
But it is important that going open won't prevent people like all those providing advices here, to contribute. This is my fear.
An alternative would be to PM files between interested contributors (or having a restricted access folder). And only publish PDF on the forum.
Don't know what is the best,
JMF
Old 23rd March 2019, 07:23 AM   #120
Hello,
The project is not completely stalled :-). I decided to start routing the project, event if it was not completly finalized. Sort of curiosity bias... Lot of professional activities aside made progressing slow.
For the routing, I took some inspiration from the TAS3251EVM (unfortunatly 4 layers) and from the TPA3255EVM (2 layers).
For hand soldering, I went to 0805 everywhere, replacing the 0402 and 0603 by bigger ones.
I still have to route the powersupply modules.
This is my first PCB of all my life... So I would really need advice about:
- the PCB, and avoiding the mysterious "ground loops",
- avoiding PCB mistakes
- tuning the values and part number of some caps and the coils.
10cmx10cm seems quite dense for the design. This was my target because of the super low PCB manufacturing prices, but 15x15 would be more reasonable.
However it moves forward ! I arrive to something like the schema below.
Other interesting news: they published more detailed information on the chip programming on TI site. I think that we have now the registry adresses.
[design log] Neat 2x170W I2S in, I2C controlled, integrated DSP amp (TAS3251)Hide this!Advertise here!
Channelmaster 6653 (Rebadged NEAT P68H Idler Drive Table & Neat GA-12 Tonearm spaceistheplace Swap Meet 0 2nd September 2017 07:19 PM
New Design: remote controlled DAC MatM Digital Source 1 18th December 2012 04:41 PM
I ned a 6ch digitally-controlled attenuator. Anyone know of a design? Spasticteapot Digital Line Level 2 27th February 2009 08:17 PM
A rotary encoder controlled integrated chip amp LM3875 justblair Chip Amps 19 31st July 2007 06:16 PM
Wanted : design PCB for relay controlled volume ElectroNick Pass Labs 135 6th July 2004 07:50 PM
Copyright ©1999-2019 diyAudio
