Using Class D for tracking power supply?
Closed Thread
Old 24th June 2018, 08:09 PM   #41
Antoinel is offline Antoinel  United States
Default Concept Supply Tracking using Class aP amplification
hellokitty123 and all. I need 2 posts to fully discuss the operation of the attached concept 'supply tracking' schematic.
1. U1 is a model power amp using the suggested tracking bipolar PSU [+Vcc/-Vcc]. U1 has an non-inverting AC voltage gain equal to 20. Make believe that it has a complementary-symmetry BJT power output stage.
2. A model signal [Vin] drives the input of U1. The positive part of this AC signal spends time between 0 to t seconds. The negative part of this input AC signal spends its time between t and t1 seconds. Zero crossing of this model AC signal happens at times 0, t, and t1. Zero crossing is/defines a value equal to zero AC and zero DC volts for Vin.
3. U2 and U3 are Class AB power amps using the system's main bipolar PSU [V+/V-]. Each power amp has a DC gain of 20 [like U1] and must be DC-coupled from its non-inverting input to its power output.. This condition is essential for the on-time and in-phase tracking.
4. The non-inverting inputs of U2 and U3 are driven by analog pulses which are derived from and are inherently synchronized with the AC input signal [Vin]. Not shown or discussed yet is the Precision Rectifier which generates the requisite analog pulses.
5. Focus operation on U2. The positive-going analog pulse signal sits atop a fixed [+0.5 VDC]. This +0.5 VDC fixed bias [absent a pulse] is multiplied by the DC voltage gain of U2 to give a [+10 VDC] at its power output which is the idle positive supply voltage for U1 [+Vcc].
6. Focus operation on U3. The negative-going analog pulse signal sits atop a a fixed [-0.5VDC ]. This -0.5VDC fixed bias [absent a pulse] is multiplied by the DC voltage gain of U3 to give a [-10 VDC] at its power output which is the idle negative supply voltage for U1 [-Vcc].
7. Focus operation on the music/AC signal [Vin] during its time interval of 0 to t seconds. Make believe its positive peak value equal to [0.3 Vp]. It follows that the peak value for Vout across the loudspeaker equals [6 Vp] from multiplying 0.3 Vp times 20 which is the AC gain of U1.
7a. Focus operation on U2. A positive analog pulse is derived from [Vin]. It has a peak value equal to [0.3 Vp] and is live in the same time interval of 0 to t of [Vin]. It is presented to the input of U2.
7b. It follows that the peak value of the positive going pulse at the power output of U2 is 6 Vp [0.3 Vp multiplied by 20].
7c.. It follows that the net magnitude of the voltage at the power output of U2 at peak is equal to [10Vdc idle plus 6 Vp] =16 Vp.
7d. This 16 Vp at the power output of U2 is the same as or is the generated tracking +Vcc supply for U1.
7e. The collector-emitter voltage [Vce] across NPN power output of U1 is initially [at idle] held constant at +10 VDC. The rise or increase of voltage at its collector olf 6 Vp [from U2 out] rises or increases at the same instant and magnitude [tracks in real time] the positive-going component of [Vout] at its emitter at the identical value [6 V]. The new dynamic collector voltage of NPN at its peak relative to ground equal 16 Vp. The new Vce of NPN is still held constant at 10 VDC. NPN operates at constant voltage; or call it cascoded!
8. During the time interval of 0 to t for Vout going positive, the negative supply of U1 is held constant at [-10VDC] because the negative component of the Vout signal is not present to enable U3 to supply track.
8b.It follows that Vce for PNP at the power output of U1 increases to an absolute peak value of 16 VDC.
Please do points [7 to 7 e] so as to to grasp negative supply tracking [-Vcc].
To be continued...
Old 24th June 2018, 10:01 PM   #42
MorbidFractal is offline MorbidFractal
Drivel.
Presumably your second post will correct your Drivel but I will not hold my breath.
Old 25th June 2018, 12:22 AM   #43
Originally Posted by MorbidFractal View Post
Drivel.
What is Drivel?
Old 25th June 2018, 12:31 AM   #44
What is Drivel?
The Thesaurus defines drivel as silly nonsense. Please continue to breathe. My promised post will follow regardless.
Best
Anton
Old 25th June 2018, 01:33 AM   #45
hellokitty123 is offline hellokitty123  United States
Not sure I like the idea of having to drive the capacitance of the tracking supply from the input.
Also I would never design U1 to be a complementary output stage. I don't agree with complementary design.
Your requirement for a rectifier seems a bit unoptimal to me. I was thinking full wave replication, after all the tracking supply is basically a voltage cascode which is useful for significant reduction of input capacitance of the stage, not to mention thermal distortion will be improved with a full wave replication I would think.
Old 25th June 2018, 10:24 AM   #46
DF96 is offline DF96  England
So the idea is to improve the efficiency of a Class A amp by powering it from two Class AB amps fed by rectifed pulses? Anyone who has looked at modern RF modulation techniques will expect this to be rather difficult to get right; timing is everything.
To me the answer is quite simple: if you want the advantages of Class A then you have to live with the disadvantages of Class A. If you don't wan't to do this then there are other classes to try, principally AB and D.
Old 25th June 2018, 11:18 AM   #47
Moderation Team is offline Moderation Team
Moderation Team's Avatar
@hellokitty123 - it's against the Forum Rules to start multiple threads on the same topic/project, as a result, your threads have been merged.
Please note: PM's sent to this account will not be answered.
Old 25th June 2018, 06:06 PM   #48
Samsara is offline Samsara  France
Originally Posted by hellokitty123 View Post
I also want to build a class D tracking power supply to reduce the power dissipation of class A circuits.
Maybe better to simply adjust bias by following signal input with opamp.
Closed Thread
Using Class D for tracking power supply?Hide this!Advertise here!
New supply tracking technology for Class D Hannes1 Class D 1 21st April 2016 01:48 PM
Leader LPS152 Tracking Power Supply dudaindc Swap Meet 8 19th May 2012 03:55 PM
LT Dual Tracking 3A Regulated Power Supply 1.25V to 20V okapi Power Supplies 56 9th July 2010 03:33 AM
tracking power supply thermal runaway Equipment & Tools 2 16th March 2010 12:19 PM
Tracking power supply ionutgaga Class D 24 17th May 2007 05:20 AM
