Hypex Ncore NC400 - input anti-alias filter?
Old 19th April 2018, 09:14 PM   #11
diyaudnut is offline diyaudnut  United States
This connector to the AMPs should help
NC3MXX-EMC - Neutrik
I am not sure about any RFI at the AMP input inside the chassis with one or more SMPS.
Old 19th April 2018, 09:17 PM   #12
Ehh… correcting myself….
These are not on the signal lines, so doesn’t help with RF inputs on them. Sorry.
Old 20th April 2018, 08:55 AM   #13
PMA is offline PMA  Europe
PMA's Avatar
I have not received a reply from Hypex technical support, but in an e-mail communication, B.P. has confirmed my findings and also confirmed that the most sensitive frequency range is near to 2 x switching frequency. So, for those who are interested, a decent LPF at the amplifier input should cure the issue.
Old 21st April 2018, 01:05 PM   #14
TNT is offline TNT  Sweden
PMA, would you have a suggestion for such a filter?
More distortion to the people!
Old 21st April 2018, 01:42 PM   #15
ds23man is offline ds23man  Netherlands
ds23man's Avatar
Or use a proper source with correct outputfiltering........
Old 21st April 2018, 01:44 PM   #16
A unit with a "flaw" should protect itself. Being wideband is not an error.
Old 21st April 2018, 02:20 PM   #17
ds23man's Avatar
Does it blow up? No
But seriously, 21 mV at 960Khz is not a normal situation.
Old 21st April 2018, 06:10 PM   #18
Reactance is offline Reactance  South Africa
Reactance's Avatar
Originally Posted by pieter t View Post
listening fatigue
hahaha!
There’s nothing worse than the smell of burned output transistors!!
Old 28th April 2018, 12:13 AM   #19
NielsMayer is offline NielsMayer
If one were to emulate the equivalent of using an XLR male connector like "Neutrik-NC3FXX-EMC blocking XLR Male" on the input to the NC400 based amp -- what circuit, inductor or capacitor values and materials (e.g. ceramic cap) would you recommend?
Adding a capacitor, a ferrite, and AC-coupling the shield is what is being done in the Neutric RF-blocking connector: Neutrik NC3FXX-EMCB Cable Connector (Black) | NZ
Is there any reason why the same circuitry can't be added to the XLR female jack for the amplifier input -- instead of building a special RF-blocking preamp/DAC -> nc400 amplifier cable with aforementioned Neutrik connector.
Thanks,
- Niels.
Old 28th April 2018, 01:07 AM   #20
- Niels.
Should have taken a closer look at NC3MXX-EMC - Neutrik for the circuit:
TBD: inductor and capacitor values?
Hypex Ncore NC400 - input anti-alias filter?Hide this!Advertise here!
FS: Hypex Ncore Nc400 Stereo System raelman Swap Meet 2 2nd January 2017 08:32 PM
FS: Hypex Ncore Nc400 Monoblocks with SMPS600 spurzheim Swap Meet 1 25th April 2016 10:39 PM
WTB: Hypex Ncore NC400 module spurzheim Swap Meet 2 5th January 2016 01:01 PM
For Sale: Hypex Ncore nc400 Monoblocks wyan Swap Meet 11 19th October 2015 01:05 PM
FS: Hypex NCore Amps NC400 SMPS600 milezone Swap Meet 2 24th July 2015 09:30 PM
Copyright ©1999-2019 diyAudio
