So what would I want to use to "turn down" the amp power? I have way too much available power for the application that I'm starting with. (although it will be excellent for future projects)
Is there a good way to limit power output, without degrading performance?
I don't want someone to damage my speakers, if they aren't familiar with the equipment. I need to put it in "valet" mode, so to speak...
I've seen many amps using that grey CD-ROM analog type cable for signal.
From the amp module to the speaker terminals? Or just from the inputs to the module?
If he means IDE/ATA cable, I would use it only for input wires. For outputs something thicker.
Would that affect sound in any way? Introduce any kind of unwanted noise or interference?
Don't have the answer yet, my project is unfinished because of broken solder iron
But I think the potentiometer isn't directly connected to any of the inputs or outputs, so it probably is noise-free.
I'd be getting the board to go inside the box, not a prepackaged module. Also, this will now be an 8-channel amp.
We're building a custom enclosure.
Would love to see how this build went. I just got a MiniDSP 2x8 and was considering something very similar.
- Class D
- Total noob - want to build (assemble) 6-channel amp
