Odd question - Class D as low-voltage AC supply
Old 29th January 2018, 09:59 PM   #1
geezertron is offline geezertron  United States
Default Odd question - Class D as low-voltage AC supply
Not sure this is the best place to take this odd idea to, but I'll take my chances. If I wanted to construct a 28V (RMS) 400 Hz power supply, could I just feed a class D amp the signal and treat the output the same way I would treat a regular AC power source?
One concern would be that the loads could be pretty reactive, for example a motor or transformer. I'm kind of dubious myself but these amps are so cheap. I just bought one for our living room for about $25 bucks. Stuck it in an old jewelry box. Works fine, the board looked like it was assembled by hand very late into the third shift but no problems yet.
Old 29th January 2018, 10:04 PM   #2
29285 is offline 29285  Europe
I would expect there is a good chance to do it that way. Just check it out, these modern class-d-chips are quite robust and fail-safe.
Old 29th January 2018, 10:07 PM   #3
DPH is offline DPH  United States
Have you looked on Digikey/Allied/Mouser/Jameco/etc for their SMPS modules?
As an example, I picked up a Meanwell LRS 350-48 (350 watts, +48/0) for something like $32; it's actually built for the job, and very cost effective.
Happy DIYing, Daniel
Old 29th January 2018, 10:19 PM   #4
FauxFrench is offline FauxFrench  France
If you look at an ordinary motor drive it is often a push-pull stage (single or double) using the motor winding as the inductance.
Buck power converters, class D amplifiers and bridged motor drives are based on the same idea.
Old 30th January 2018, 12:29 PM   #5
DUG is offline DUG  Canada
28Vrms is almost 40V peak.
You need an amplifier that is a BTL with a supply higher than the 40Vp.
TPA3255 would fit this requirement.
For a SE drive look at TDA8954. ( +/- 42.5V supplies )
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 1st February 2018, 01:17 AM   #6
whizgeek is offline whizgeek  Ireland
In a BTL does the PSU need to be only 20V ??
Old 2nd February 2018, 11:08 PM   #7
Old 3rd February 2018, 02:11 AM   #8
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Something like a TAS5630 mono board with a 48V supply.
Odd question - Class D as low-voltage AC supplyHide this!Advertise here!
voltage / supply question mr ed Class D 4 13th September 2015 03:25 AM
Class D amplifier voltage supply help Mr Smith Class D 6 6th December 2014 05:43 AM
why this class D power supply no high voltage side electronic cap? greenamp Class D 10 29th January 2012 06:32 PM
Supply voltage doubler question ashok Power Supplies 33 16th July 2010 08:49 PM
Safe Working voltage of output Transistors in class AB amps with +/- supply rajeev luthra Solid State 3 31st July 2004 07:58 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
