class d tda8950 blown output resistor ... need fix
Old 27th January 2018, 03:46 PM   #1
dannyjmf is offline dannyjmf  Malaysia
dannyjmf's Avatar
Default class d tda8950 blown output resistor ... need fix
hi members ...
here i have a TDA8950 with its blown 22Ohms resistor which is the speaker out resistor. During the time it blows it was connected to a failed eq module which has oscilation issue ... that moment no speakers were connected to this tda8950 module when it happened ... there were pictures of the burnt mark shown
I intend to repair this amplifier module by replacing the blown 22Ohms resistor ... but since it is my first time working with class d amplifiers for repair ... if the output resistor blows, anything else should i look out for? now the amplifier module has been pulled out from its chassis and after the repair i would conduct a standalone test for it before re-installing it.
helps were really appreciated ...
Mohamad Danny Al Saleh
Old 27th January 2018, 05:20 PM   #2
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Without a load the output RC absorbs all of the high frequency resonance and you end up with your current situation. Replace the resistor and don't power it without a load again.
Old 28th January 2018, 01:06 PM   #3
coolmaster is offline coolmaster
I was building a speed controller with this same module. Can't recall what I did, one 22ohm resistor smoked but not to the extent of open circuit. I promptly replaced with a same 1W metal oxide of the same value and its been trouble free since. This is after I made sure whatever connections are all correct. I don't think there's anything else to look for. The protection circuit should kick in if there's anything seriously wrong.
class d tda8950 blown output resistor ... need fixHide this!Advertise here!
Blown resistor in Aikido LV wingding611 Tubes / Valves 13 10th October 2017 12:16 PM
TDA8950 Class-D BTL Stereo Amplifier Board cRash1001 Class D 8 19th August 2017 10:43 AM
Blown screen resistor trombone Tubes / Valves 3 12th November 2012 04:51 PM
FLI 900s blown resistor Mx5Mayhem Car Audio 2 18th November 2011 10:33 PM
Blown up resistor in S-5 amp kit... fenpark15 Tubes / Valves 24 7th January 2008 02:40 AM
Copyright ©1999-2019 diyAudio
