TDA7498E Mod
TDA7498E Mod
Old 23rd January 2018, 12:34 AM   #1
drauzinho is offline drauzinho  Brazil
Default TDA7498E Mod
Does anyone that have these boards knows any improvements for better sound quality/better bass ? Thanks.
TDA7498E Digital Placa Amplificador de Potencia 2x160 w Mono Amplificador de Potencia Digital de Alta potencia Estereo BTL220W em Amplificador de Eletronicos no AliExpress.com | Alibaba Group
Old 23rd January 2018, 01:17 AM   #2
r_kalar_2 is offline r_kalar_2  Bangladesh
Follow and post here:
Ebay cheap TDA7498 boards
Old 23rd January 2018, 01:57 PM   #3
FauxFrench is online now FauxFrench  France
I have tried the board with good results.
A brief test can be found on DIYBudgetAudio.com under "TDA7498E based class D power amplifier".
A modification is suggested.
Good firm bass is to a large extent a question about a power supply that can deliver rapid current transients without loosing tension, thus, good large decoupling capacitors and sufficient power.
Old 23rd January 2018, 02:11 PM   #4
FauxFrench, very good info at the site, thanks a lot. The only thing I couldn't be shure is to which diodes is he talking about. Can you check with me if it's the D3 and D1 from the PCB Layout ? Thanks.
Old 23rd January 2018, 02:20 PM   #5
The two polarity protection diodes, which are suggested shorted, are the two SMD diodes near the output chokes and tuned some 45 degrees compared to the other components.
TDA7498E ModHide this!Advertise here!
TDA7498E Board drauzinho Class D 5 12th October 2017 10:00 PM
TPA3255 or TDA7498E drauzinho Class D 10 4th September 2017 03:47 PM
TDA7498E vs IRS2092 based amp pguerin Class D 13 12th July 2017 10:23 AM
Interesting cheap TDA7498E amplifier... apocalipsis1234 Class D 1 24th April 2015 08:59 PM
Its not diy but what do people think about these TDA7498E amps on ebay. wayward91 Class D 10 5th January 2013 03:47 PM
Copyright ©1999-2019 diyAudio
