TPA3250 somebody is listening?
Old 26th July 2019, 07:56 AM   #961
scxrye is offline scxrye
Hi!
I've replaced the ne5532 op amps in the FX502SPRO with two opa2604, But after reading trough the topic, I'm not so sure if its as easy as just pop in, and out.
Is it safe to replace the two ne5532 with Opa2604?
Old 26th July 2019, 10:33 AM   #962
Turbowatch2 is offline Turbowatch2  Germany
If you put them in with the right orientation, which is no easy task, as they fit right and wrong, the worst thing that can happen, you will not hear any difference. Eelectrically they work in the same spot / conditions.
Chances are good you will hear something, because most China ampīs have fake NE5532 for a obvious reason: It is an expensive, high quality OP-amp.
So you might hear the difference of some NE5532 labeled 2 Cent OP amp to your expensive OP amp. Well, only if it is no fake opa2604, like the ones from eBay.
In that case (eBay) you might hear no difference...
Confusing, isnīt it?
Old 26th July 2019, 10:51 AM   #963
I've already swapped them, I'm more worried about the instability mentioned here
than orientation. The Opa2604 is from a local store. I've been promised it is real. And there is an audible difference.
The ne5532 came with the unit is quite harsh, overly bright. The Opa2604 takes that edge away, sounds warmer and more musical.
Old 26th July 2019, 10:57 AM   #964
Just like I experienced, changing fake NE5532 for a real one...
Great to hear you improved!
Instability should be a real design fault.
Old 19th August 2019, 04:28 PM   #965
pav26 is offline pav26
Hello,
Today I recieved my FX502PRO. As expected, it sounded far too bright as standard, with a recessed and somwhat muddy midrange. I bought some LME49720NA op-amps from a reputable source and quickly replaced the "NE5532" op-amps. The replacement was very easy using tweezers to pull the old op-amps out and slot the new ones in. The amp now sounds much better! Much less sibilant and the midrange has been brought forward. I think it's still a tad bright at times, but it is certainly far better than standard.
Here is what mine looks like - V5 board:
I did notice it seems to get warmer now with the op-amps changed. Anything to worry about?
Old 19th August 2019, 06:13 PM   #966
chermann is offline chermann  Austria
Hi PAv
"I did notice it seems to get warmer now with the op-amps changed. Anything to worry about?"
i would say no. if the sound is better/ you like more you push the volume more louder so more power is going to your speakers ...so donīt worry....enjoy
chris
Old 19th August 2019, 06:35 PM   #967
Hi Chris,
Super! Thanks
Pav
Old 25th August 2019, 03:05 AM   #968
rvfixer is offline rvfixer
Could you please tell me where to purchase that amp . Thank you Randy
Old 25th August 2019, 12:51 PM   #969
Hi
Available at Amazon - just type in TPA3250 (FXaudio - FX502sPro) about 65 Euro with PSU - or you buy at Alixpress 45 Euro with PSU.
without PSU - 34 euro !
2019 FX Audio Neue FX 502SPRO HiFi 2,0 Volle Digitale Audio Power Verstarker Annahme TPA3250 High Power 70W * 2-in Verstarker aus Verbraucherelektronik bei Aliexpress.com | Alibaba Gruppe
chris
TPA3250 somebody is listening?Hide this!Advertise here!
MPA 3250 Amp johnmik Solid State 18 8th May 2019 05:32 PM
RD Audio 3250.1 Deadly Sones Car Audio 1 10th July 2013 05:51 PM
RD Audio 3250 V2 S Merlington Car Audio 3 28th February 2013 05:55 PM
What are you listening to? MikeW Pass Labs 36 20th June 2011 01:54 AM
Denon DOA-3250 mike49504 Car Audio 2 12th November 2010 08:17 PM
Copyright ©1999-2019 diyAudio
