TPA3250 somebody is listening?
Old 22nd January 2019, 07:35 PM   #811
chermann is offline chermann  Austria
Originally Posted by doctormord View Post
Did you earthed the case additionally?
you are right!....no its not...but its in the pipeline...not tonight..
tomorrow i change the switch indicator lamp (desolder + resolder) and add an extra cable to the housing as short as possible
btw...the terminals for 24v are reused by the YJTPA3255 board
Old 23rd January 2019, 08:07 AM   #812
Originally Posted by chermann View Post
Questions to the experts here...
should i solder the 3rd pad of the coils (würht 7443631000) together and connected to ground?
what happend? Better SQ?
thanks you in advance
chris
pump it up....
Old 23rd January 2019, 11:37 AM   #813
doctormord is offline doctormord  Germany
doctormord's Avatar
Nothing, it isn't connected to anything.
Old 23rd January 2019, 12:18 PM   #814
..hhhhmmmm...... i thought that the big housing of the coils can act like an grounded shield...no?
Old 23rd January 2019, 12:29 PM   #815
doctormord's Avatar
Don't think but read the datasheet.
TPA3250 somebody is listening?-7443631000-png
The pin is only molded into the bottom plastic frame, it isn't connected to anything. The "housing" ist the core, not a dedicated "shield".
Old 23rd January 2019, 12:40 PM   #816
thank you...
Old 23rd January 2019, 12:56 PM   #817
Default foil at opmap ??
Hi doctor
as strongbow60 give me many posts before this hint -foil over the opamp..... i ask:
at the DAC post i see a foil over the TDA1541 chipBuilding the ultimate NOS DAC using TDA1541A
is this worse a try?
chris
Old 23rd January 2019, 01:17 PM   #818
atmo is offline atmo
Good evening
After a moment where my son came in and go near to the naked psu (LRS-150-24) and asking 1 meter before he is touching it.....
....i decided to build quickly a closed psu
the only thing i realized now is that the power button is wrong connected because the lamp on it is always on....
chris
which project box did you use for this? thanks.
Old 23rd January 2019, 01:32 PM   #819
because i have to react quick i used amazon
40 euros.....and silver only...
https://www.amazon.de/gp/product/B07...?ie=UTF8&psc=1
Old 23rd January 2019, 01:39 PM   #820
voltwide is offline voltwide  Ireland
Hi doctor
is this worse a try?chris
I do not think so. Even if there is some minor difference in the area of -100dB - you won't hear it - and you cannot measure it yet.
tuby or not tuby, that is here the question!
TPA3250 somebody is listening?Hide this!Advertise here!
MPA 3250 Amp johnmik Solid State 18 8th May 2019 05:32 PM
RD Audio 3250.1 Deadly Sones Car Audio 1 10th July 2013 05:51 PM
RD Audio 3250 V2 S Merlington Car Audio 3 28th February 2013 05:55 PM
What are you listening to? MikeW Pass Labs 36 20th June 2011 01:54 AM
Denon DOA-3250 mike49504 Car Audio 2 12th November 2010 08:17 PM
Copyright ©1999-2019 diyAudio
