TPA3250 somebody is listening?
Old Yesterday, 08:27 PM   #801
chermann is offline chermann  Austria
thank you Voltwide
..but i guess without external sound card and e.g. ARTA its not possible without damaging the amp(output filter)
what is the disadvantage of measuring with sound card (24/192khz) and software(ARTA) vs Spectrum analyzer e.g. rigol DS705 except the price???
with sepctrum analyser i can do some video measurements or digital too....
Old Yesterday, 09:11 PM   #802
doctormord is offline doctormord  Germany
doctormord's Avatar
The Rigol is 100kHz - 500MHz, way out of interesting frequency range.
External soundcard + Arta is very versatile. We (at stromrichter.org, i.e. voltwide, me and others) use cheap "EMu Tracker Pre" boxes to do the measurements. These can be modded for differential output easily and can measure fully differential with an external attentuator. You'll find these boxes for about 25€ at eBay (Kleinanzeigen)
Old Yesterday, 11:03 PM   #803
voltwide is offline voltwide  Ireland
The disadvantage is you are restricted to audio band measurements.
The disadvantage of Rigol FFT is its poor resolution of 8bit being the bottleneck for usable dynamic range of FFT, for instance.
Bandwidth of Rigol is 100MHz - thus increasing input noise into the mV range whereas the soundcard can resolve several microVolts.
As long as you are measuring audio it is hard to top a soundcard setup.
E = 0.5*m*c & opinion != fact
Old Yesterday, 11:15 PM   #804
thank you Voltwide
You can measure with any arbitrary sound source as long as output ringing is kept within sane levels.
And if you increase output level above that limit, the inherent current limiter should shut down the amp.
The only scenario known to me that will destroy the amp is excessive ringing with output inductors saturating. In that case output current may rise too fast before the internal current limit trips. El cheapo small inductors increase that risk.That is why TI specify a minimum output inductance in their data sheets. To be on the safe side, saturating current of the inductors should be bigger than max overcurrent trip value of the amp.
Old Today, 06:04 AM   #805
Thank you! i understand...
TI DS = minimun inductance is 5H
Old Today, 06:11 AM   #806
Thank you both....it was an idea to share the "future" equipment with my brother....but as i can read....its for audio (video....) nonsense
At stromrichter i found no pic or diagram what is exactly needed....but THD measuremnt is actually in my pipe but i have too much to do.......to close some projects
Old Today, 01:48 PM   #808
AAhh.. the first i dont know..thanks
link 2+3 i read
thx
TPA3250 somebody is listening?Hide this!Advertise here!
MPA 3250 Amp johnmik Solid State 17 14th October 2018 03:42 PM
RD Audio 3250.1 Deadly Sones Car Audio 1 10th July 2013 06:51 PM
RD Audio 3250 V2 S Merlington Car Audio 3 28th February 2013 06:55 PM
What are you listening to? MikeW Pass Labs 36 20th June 2011 02:54 AM
Denon DOA-3250 mike49504 Car Audio 2 12th November 2010 09:17 PM
Copyright ©1999-2019 diyAudio
