TPA3250 somebody is listening?
Old 17th January 2019, 07:33 AM   #781
chermann is offline chermann  Austria
Originally Posted by doctormord View Post
The IC shown there is a TPA3251 with thermal pad on top.
oh...
but its nevertheless a very good idea
Old Yesterday, 08:44 AM   #782
Splkn is offline Splkn
Originally Posted by chermann View Post
from post 775
so the tpa 3250 has a gain of 26db so with this opamps config i get about 33db so its 7db more gain
is that correct?
so the volume knob- potentiometer is a voltage divider for the input and the inverted opamp has a gain about 7db....correct?
which values should i find an the pcb to get this? can some fresh brain and expert help me?
thanks chris
On - forum.vegalab.ru they are engaged in the Hypex UcD amplifier and write:
«Completely excluded OU as well as WG. The signal is fed directly to the modulator. Gain is enough for comfortable listening directly from the source. The input impedance is not enough, but the output buffer of the source pumps. This option is more like.» They have an input impedance of the amplifier (modulator) of 10 kom, the TPA3250 has a resistance of 24 k per channel. Or 12kom with two channels connected in parallel.
Old Yesterday, 09:49 AM   #783
Hi Splkn
First .....Thank you that you try to explain me ...but i didn´t get your point.
TPA3250 somebody is listening?Hide this!Advertise here!
MPA 3250 Amp johnmik Solid State 17 14th October 2018 03:42 PM
RD Audio 3250.1 Deadly Sones Car Audio 1 10th July 2013 06:51 PM
RD Audio 3250 V2 S Merlington Car Audio 3 28th February 2013 06:55 PM
What are you listening to? MikeW Pass Labs 36 20th June 2011 02:54 AM
Denon DOA-3250 mike49504 Car Audio 2 12th November 2010 09:17 PM
Copyright ©1999-2019 diyAudio
