TPA3250 somebody is listening?
Old 13th August 2018, 05:02 PM   #661
Cardone is offline Cardone
Default I'm new and greet everyone
Hello everyone
After reading all 66 pages a FXAUDIO FX502SPRO TPA3250 ordered + 2x LME49720NA .....
I have to say that the sound is very good ....
Moodeaudio is installed.....
Old 13th August 2018, 06:32 PM   #662
chermann is offline chermann  Austria
Originally Posted by meq123 View Post
Thanks to this thread, I went ahead and modified my Amp as per posts by @chermann and @irribeo.
Anyway, all works now, though not had time to do any real listening tests. Thanks again to all.
sorry i was on holidays....
thanks linuxfan for your very good explanation.
Very well done Meq123. good job.
chris
Old 13th August 2018, 06:33 PM   #663
Originally Posted by Cardone View Post
Hello everyone
jop...the soud and price ratio is very good.....
Old 14th August 2018, 08:51 AM   #664
petersv is offline petersv  Norway
I replaced the LM317 resistor with another 0805 surface mount 3k6 and soldered the cap across it - as shown in pic 1. Pic 2 shows the extra heatsink and bypass caps in place. I cut a rectangle from an old (dead) PC PSU heatsink that was the perfect depth, then glued it in place with heatsink epoxy sandwiched with a silicone transistor heatsink pad to isolate it from the PCB. I cut around an existing threaded hole in the heatsink and used that to attach to the bottom of the case (took some very careful measuring to get the hole in the case correctly!).
Hi all, are these component modifications/swaps advised for everyone using the bundled PSU? I'm running some Dali Suite 2.5 4 Ohm speakers, and it sounds quite ok, and I dont have any problems or error lights.
Old 14th August 2018, 10:25 AM   #665
hi peter
my personal target for this amp is to use the original psu.= 24V
internal regulator is not correct implemented by fx audio because the setup of lm317 is set to 22,7V and so the regulator is not working. The datasheet requires 3V differents about input and output of the lm317. so the regulator is not working correctly and you might get the "noise" of the psu into your amp.
yes no problems with error light- error light comes if the impedance gets lower than 4 ohms / or if you get undervoltage = psu get down. i tred a test with 2 ohms load...not possible with this psu.
chris
Old 14th August 2018, 11:28 AM   #666
Thanks for the replay Chris. I have some SMD resistors, should I place a 3k6? I see that there is a capacitor as well added to this resistor, what is the purpose of that?
Kind regards, Peter
Old 14th August 2018, 07:45 PM   #667
meq123 is offline meq123
Kind regards, Peter
See post # 522 (TPA3250 somebody is listening?)
Old 15th August 2018, 04:56 AM   #668
Thx meq123.
Old 15th September 2018, 12:36 AM   #669
forestsgump is offline forestsgump
Hello everyone
Howdy Cardone, I also bought some LME49720NA for my FX502SPRO
For the sake of my authenticity verification, how does your LME49720NA look like?
Top# Element14's or Bottom# RS-online's
Old 15th September 2018, 07:56 AM   #670
Hello, I bought it from Conrad Electronic.
Under the name - Linear IC - Operational Amplifier Texas Instruments LME49720NA / NOPB Audio PDIP-8
Linear IC - Operationsverstarker Texas Instruments LME49720NA/NOPB Audio PDIP-8 kaufen
At RS-online's should be the same ....
Ciao
TPA3250 somebody is listening?Hide this!Advertise here!
MPA 3250 Amp johnmik Solid State 16 10th March 2017 06:50 PM
RD Audio 3250.1 Deadly Sones Car Audio 1 10th July 2013 05:51 PM
RD Audio 3250 V2 S Merlington Car Audio 3 28th February 2013 05:55 PM
What are you listening to? MikeW Pass Labs 36 20th June 2011 01:54 AM
Denon DOA-3250 mike49504 Car Audio 2 12th November 2010 08:17 PM
