TPA3250 somebody is listening?
Old 22nd April 2018, 01:18 PM   #411
swank42 is offline swank42
I have a question about power used. The FX502SPRO is quite powerful for my high-efficiency speakers, so in order to have a usable volume range, I turn down the output of my Chromecast so that I can use more range on the FX502SPRO's volume knob.
2 questions = does that mean that the amp is using more power? Does it mean the 3250 chip will generate more heat?
I don't know if the answer is yes to both of those or if the chip is at the same power and the volume pot is just cutting the output.
Old 22nd April 2018, 01:29 PM   #412
irribeo is offline irribeo  Netherlands
what value resistors are around the opamps ? do the opamps add gain ?
Old 22nd April 2018, 01:34 PM   #413
chermann is offline chermann  Austria
hi swank42
i think you are too afraid about the heat of this amp. general this chip has a thermal and OVC (over current protection) circuit implemented! so dont worry.
the amps job is to amplifie the level of his input to a regulated (volume knob) gain. depending of the voltage of psu and the max technical requiremnt of this amp you get more or less the possible "power" - if the psu keeps stable.
the position of the volume knob or your volume level of the amps input is not releated to the power. it should give you a wider range for adjust your needed volume during playing music.
youknow. the volume knob of the fx502spro is very sensitive, that means little movement of this knob is generating a big step louder.
clear?
Old 22nd April 2018, 01:43 PM   #414
hi
yes you requested this at page 31 #310
..but actually try to keep this because of no practice in soldering in smd.
Old 22nd April 2018, 02:01 PM   #415
I do tend to look at Valverde (or Rodriguez) sprinting uphill, although I personally need to step off my 27 gear mountainbike on some of the Belgium hills that hardly slows down those two Spanish.
Old 22nd April 2018, 02:15 PM   #416
aaahh...your are a cyclist too...
its recording on my HDD of my hd SAT reciever....
garden and family is in a parallel process
Old 22nd April 2018, 02:25 PM   #417
Originally Posted by chermann View Post
i have just a smal room with smal speakers and actually i play some more punchy music..........zhu....gogo penguin...
but i think i psuh the amps not so hard.
yesteday i forgott to low down the level at tidal and i played "a hundred moons" by gogopenguin, tidal level nearly max = 92 and the fx502s was set about 12 o clock --> at second 11 of the title the amp shut down on the left channel and push down the right channel -->with error led blinking. after switch off and 5 seconds wait it works again.
yes i can feel the difference slightly.
happend again - amp 2 BB2134 but exactly some as obave discribed
but other channel shut down = right channel
switch of ...3 sec waiting.....and go ahead with volume 83 volume at tidal... !
nice afternoon...
Old 22nd April 2018, 06:43 PM   #418
Default ..psu check...
Hi
i used the "stronger" (current max 16A). its a psu with 15V:
corally 250Watt psu
corally netzteil 250W - Google Search
my impression is that this psu really give me exact the same volume of music and a sound with more "darkness". the disadvantage of this psu is that the fan is real loud. so i have to play tiltes with more action
i tryed to push the amp as hard as described before. the amp is not switching of --> so the previous shut down was a weakness of the original psu.
Old 23rd April 2018, 05:44 AM   #419
Default ...smsps measurements...
Good morning
yesterday i checked this RC smps shortly. recommended 15V /16Amax
my loadbox has 3x4,2 Ohm /100W resistors = 1,4 Ohms overall resistor.
10,53 Ampere at 14,74Volt is fine. no noise measurements with scope.
the fan is very loud.
Old 23rd April 2018, 07:00 AM   #420
How to make noise with a 10 watt amplifier
TPA3250 somebody is listening?Hide this!Advertise here!
MPA 3250 Amp johnmik Solid State 18 8th May 2019 05:32 PM
RD Audio 3250.1 Deadly Sones Car Audio 1 10th July 2013 05:51 PM
RD Audio 3250 V2 S Merlington Car Audio 3 28th February 2013 05:55 PM
What are you listening to? MikeW Pass Labs 36 20th June 2011 01:54 AM
Denon DOA-3250 mike49504 Car Audio 2 12th November 2010 08:17 PM
Copyright ©1999-2019 diyAudio
