Kool Mu core chokes for the class D output chokes?
Old 8th October 2017, 10:44 AM   #1
rhythmsandy is offline rhythmsandy
Default Kool Mu core chokes for the class D output chokes?
Im planning to build an IRS2092 amp and wanted to know about the Kool Mu cores for the output choke. Can anyone tell me that is it excellent core for both quality and transient power transfer is good in that?
Old 8th October 2017, 11:18 AM   #2
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
I believe Kool Mu is pretty much the same as Sendust. Can't help feeling its going to be rather lossy compared to a gapped ferrite core.
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 8th October 2017, 11:52 AM   #3
Magnetics - Large Kool Mu Core Shapes
Just have a look at the comparison with various core materials.
you can check this thread where its mentioned as powdered iron cores getting hot at 400KHz
Amidon T200-2 core suitability for 1kWrms?
Old 8th October 2017, 12:02 PM   #4
how much % lossy?
on the site it states that Kool Mu has lower losses than Powder iron core.
Magnetics - Kool Mu and Powdered Iron Comparison
Old 8th October 2017, 01:19 PM   #5
abraxalito's Avatar
Here are the plots for losses vs frequency from Ferroxcube. You'll be operating between 300 and 500kHz typically for classD audio. I'm seeing around 6W/cc @0.1T.
Old 9th October 2017, 12:45 AM   #6
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
A few years ago I wanted to get some Ferroxcube TN26/11-3C20-A113 gapped toroids but couldn't find anywhere to buy them in small quantities.
http://ferroxcube.home.pl/appl/info/...0amplifier.pdf
Old 9th October 2017, 02:50 AM   #7
I have accessibility for the Kool Mu cores from Maginc so as per the specs wouldn't that help?
Old 17th October 2017, 02:25 AM   #8
Can anyone confirm me as I see the core losses in higher frequencies is less in this.
Generally for how much output power the wattage of the choke can be considered like
for 1000WRMS Class D amplifier so does it require 50W power handling choke? with heavier gauge wire.
Old 19th October 2017, 07:44 AM   #9
kartino is offline kartino  Indonesia
kartino's Avatar
MS157060 is commonly used for 1000W typical.
T157-2 will be better
Old 19th October 2017, 11:24 AM   #10
rafsky is offline rafsky  Italy
Send a message via MSN to rafsky
You can also use classic ETD ferrite (N87, N97 or similar) with appropriate gap, the winding length is usually less, so less copper dispersion, an ETD29 from my experiments was much better than 130.2 up to 0,5Kw
Kool Mu core chokes for the class D output chokes?Hide this!Advertise here!
Amorphous vs. Nanocrystalline core for PSU chokes (subjective opinions only please) 50AE Parts 5 31st May 2017 02:55 PM
FS: 4x 10H 215mA WIDEBAND CHOKES (layered chokes) DIYspaceW Swap Meet 5 13th March 2013 05:10 PM
Iron core chokes & Poly film caps up on Ebay philsaudio Swap Meet 0 6th October 2012 12:31 PM
four high-power iron-core chokes 3mH cocolino Swap Meet 0 14th May 2007 12:42 AM
Partridge Oil Filled C-Core Chokes 1H @ 500mA mozfet Swap Meet 1 28th October 2002 07:27 PM
Copyright ©1999-2019 diyAudio
