What is wrong with TPA3255?
Old 9th January 2019, 08:46 PM   #701
chermann is offline chermann  Austria
well done...nice wood housing
sorry maybe i miss it...which psu do you use?
chris
Old 10th January 2019, 04:00 AM   #702
FerChin79 is offline FerChin79
Thanks Chris. The psu is connexelectronic Smps300R 38v adjusted to 36v
Old 14th January 2019, 06:41 PM   #704
not easy to say what SQ compared to the normal YJTPA3255
but 40$ with housing.... but i guess that the blue thooth will give some noise, i read at other chip boards
this board looks very similar, ...or.....but its 2.1
GHXAMP TPA3255 Digital Hifi Amplifier Board 150W*2+300W Class D 2.1 Channel High Power Amplifier Board DC 30V 48V 1pc-in Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
so its not BTL = best performance
its SE...
Old 16th January 2019, 09:07 AM   #705
zeroFILL is offline zeroFILL  Viet Nam
@FerChin79, @chermann: Can you guys tell what is the Op-Amp chip in your boards? Thanks!
Old 16th January 2019, 09:31 AM   #706
on my first version of my board (with LM2575S + LM317 i had the TL072 (fakes)
on the second version of my board i had the LM2575T regulator and the TL072 too, but after some strange spike voltwide remind me that this could be lm538 or so = somthing worse than the TL072
...its postest earlier...
Old 16th January 2019, 03:43 PM   #707
I replaced the stock op amp (TLO72) with OPA2132. Fo now ths the mods I did. I bought in arrow.com
Old 17th January 2019, 03:56 AM   #708
Thank you! I think that op-amps are very important but we seem to have no choice since every Chinese's TPA3255 boards have the same cheap op-amps
Old 17th January 2019, 05:57 AM   #709
after listening test with my first boards and with changed input caps...i changed it to 10F/16V elna silmic 2 its sounds not as bad!
Voltwide state a lot of pages before that this (original) old version of opamp is not bad sounding. i can agree....
Old 27th January 2019, 03:14 AM   #710
linuxfan is offline linuxfan  Australia
Still on the subject of opamps, can anyone offer an opinion why all of the TPA32xx boards currently available choose to use NE5532 (or equivalent) at the input for SE-to-differential conversion?
Why would they not use dedicated differential line-driver IC's such as THAT1646 or DRV134 or SSM2142 ? I would have thought that these dedicated IC's would be optimal?
What is wrong with TPA3255?Hide this!Advertise here!
TPA3255 - all about DIY, Discussion, Design etc. lms Class D 1002 Today 09:31 PM
My 1st Class-D Amp -TPA3255 with PFFB JohnnyInBris Class D 19 13th August 2018 03:26 PM
FS: TPA3251 TPA3255 2.0 BTL Amplifier doctormord Swap Meet 11 13th August 2017 08:14 PM
TPA3255 Amplifier for Car Audio System GABRIELITEDEVIL Class D 6 1st January 2017 10:37 PM
Wrong Voltage / current on BoZ... or Wrong Measuring ? gionag Pass Labs 8 14th May 2008 12:24 PM
Copyright ©1999-2019 diyAudio
