Analog input filter on class D amplifier
Old 24th June 2017, 09:33 PM   #1
David1998 is offline David1998
Default Analog input filter on class D amplifier
Hello,
Is it supposed to be possible to use an analog filter (RC filter, with/without OpAmp) to filter out certain frequencies before amplifying the signal with a class D amplifier? It seems like with everything I try, the audio quality goes down dramatically. Even if I use a unity gain OpAmp buffer, the audio sounds like crap.
I do use cheap Ebay class D amplifier modules, I've tried the PAM8610 and the TPA3110, but they both sound just fine without the filtering.
When I search about this on Google, it seems like everyone uses either a DSP or an output crossover of some sort.
Thanks in advance.
Old 24th June 2017, 11:06 PM   #2
vacuphile is offline vacuphile  Netherlands
vacuphile's Avatar
If they sound just fine, why change a winning team? Perhaps you could explain in a bit more detail what you want to accomplish and how.
I disagree that we don't agree.
Old 25th June 2017, 05:04 AM   #3
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Grounding problem resulting in increased noise floor? HF interference? The input signal to a class D amplifier should be as free as possible from >20khz components such as produced by digital circuits.
I use to feel like the small child in The Emperor's New Clothes tale
Old 25th June 2017, 06:13 AM   #4
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
When an opamp follower stage sounds lousy pay attention to input RF filtering and power supply purity.
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 25th June 2017, 10:32 AM   #5
Thank you all for the replies so far. I will try your suggestions so far.
What I'm trying to do is boost the lower frequencies a little, since I want more bass. Eventually I want to make my own Bluetooth portable speaker. Since class D amplifiers offer a high power output with a relatively low battery voltage, and are super efficient, this would be a great option for the amplifier.
I'm thinking of using this kind of filter:
Which should have a frequency response like this:
I tried it with a TDA2030 class AB amplifier and I finetuned the R and C values. This works good but now I want this to work with a class D amplifier
Old 25th June 2017, 11:33 AM   #6
R.I.P.
That looks terrible.
You have a step function with +46.8dB in the low bass region and -13.2dB in the high treble region.
The band through the remaining audio band is NOT FLAT. It slopes from +46dB to -13dB over six and a half octaves. That's ~ 9dB per octave.
No wonder it sounds crap.
Just use a normal RF input filter. Set it somewhere around 30kHz to 200kHz.
It can be a passive RC using a 1k resistor and 1nF capacitor.
If you think you need a more severe filter, then adopt an active S&K unity gain low pass. Set this to somewhere between 25kHz and 100kHz.
Do the interference filtering first.
Then read up on doing a bass boost, but apply that separately. Maybe make it defeatable/switchable.
regards Andrew T.
Old 25th June 2017, 11:44 AM   #7
vacuphile's Avatar
Hi David,
If you want tone control, it might be worthwhile for you to look at a Baxandall schematic and build one if you like it.
Old 25th June 2017, 12:14 PM   #8
R.I.P.
Here's a nice explanation of RC filtering:
https://www.youtube.com/watch?v=OBM5T5_kgdI
regards Andrew T.
Old 25th June 2017, 01:14 PM   #9
Thanks for the replies.
Well I did finetune the R and C values, according to simulations and calculations.
By the way, I got the filter configuration from this document I found the other day. http://labkit.ru/userfiles/file/docu...st_Filters.pdf
I tested the filter with these component values:
Which should give this kind of response: (Input voltage 1V sine wave)
But thank you, I will try the interference filtering.
I do study Electrical Engineering, so I'm familiar with these simple RC filters. I've also used the Sallen-Key filter before.
But I wanted to boost the bass a little, while not completely removing the higher frequencies.
Hi David,
Thank you sir, I will look into that type of filter too.
Analog input filter on class D amplifierHide this!Advertise here!
Desire to build a Class D amp with analog liner power supply Grannyring Class D 5 22nd March 2017 01:31 PM
new class-D amp IC from Analog Devices pato3 Class D 0 19th December 2016 08:02 PM
Class AB Amplifier - New to the analog world ea6b607 Solid State 40 28th March 2011 08:28 PM
New Class D chip fro Analog Devices AAK Class D 9 3rd February 2005 11:36 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
