Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Class D Switching Power Amplifiers and Power D/A conversion |
#481 |
Price level should be considered with relation to other brands, not to a NC400 combo which is heavily overpriced.
More interesting seems to be to discuss differences in quality and options of DSP sections, and what impact these might have on the sound quality of built loudspeaker systems. |
#482 |
1. NC400 is the first generation Ncore, a lot have been improved in the ncore designs.
2. ADC, Dac and dsp are comparable or better than used in the DLCP. |
#483 |
Can you say something about the improvements over NC400. I suppose we talk about the round NC400..
More distortion to the people! |
#484 |
And most important - do they run cooler than the AS ones?
#485 | |
Replace current amp with 2x FA253. To get an idea of the amps i will use it first without dsp. just replace the amp. After that make the current loudspeakers full active with dsp. Then a new set of speakers, full dsp, if projects above work out well. Exiting stuff :-)
Allo USBridge Sig > Allo DigiOne Sig > S/PDIF > Hypex FA 253 > OBL-15 with Viawave GRT-145 |
#486 |
Maybe I shouldn’t say so, but when comparing to NC 400, I thought the prices were very reasonable .
Johan-Kr |
#487 |
Does anyone know what the analog input latency of the new fusion range is?
#488 |
Analogue input latency approximately 350uS
Digital input latancy approximately 1,8mS @ 96kHz input sample rate |
#489 |
Thanks Antana,
How does that compare to the PSC2.400d? |
#490 |
The manual of the PSC2.400 says "Analogue Latency 1,12 ms" and "AES Latency 3,58 ms"
Thread | Thread Starter | Forum | Replies | Last Post |
Hypex Plate Amps | madtrapper | Class D | 1 | 14th March 2014 06:21 PM |
Opinions wanted on using the Hypex 2.4 plate amps? | SpinMonster | Multi-Way | 2 | 3rd April 2012 09:26 AM |
Hypex plate amps | chatziva | Class D | 3 | 29th July 2010 04:33 PM |
HYPEX plate amps | Glen1 | Subwoofers | 0 | 27th January 2006 03:22 AM |
New To Site? | Need Help? |
