The New Hypex Fusion Plate amps
The New Hypex Fusion Plate amps Please consider donating to help us continue to serve you.
Old 22nd October 2019, 11:43 AM   #1681
cowanaudio is offline cowanaudio  Australia
cowanaudio's Avatar
Originally Posted by fedde View Post
@DS23man: do you have any advice on the mounting the plate amps in MDF? Can I make this tight around the PCBs or do I need to reserve some room (e.g. a few cm below the PCBs or is it required even around the PCBs)?
Fedde
I do, and I can tell you if the cutout is too small you will have trouble getting the insulating material on the board through the hole, too big and the screws will have nothing to bite into. Best you buy your modules before you cut. Depth wise only a small clearance is required.
Don't Procrastinate....Just Do It!
Old 22nd October 2019, 04:37 PM   #1682
fedde is offline fedde  Netherlands
The Fusion package is waiting for me at home...
Thanks to all for the answers!
Fedde
http://www.fedde.nu, gainclone, non-oversampling DAC and open baffle audio projects...
Old 22nd October 2019, 06:49 PM   #1683
The good news: my Fusion plate amps arrived. The bad news: the PCBs are curved around the transformer.
Does anyone has this issue as well? Should I be concerned about it and return them?
Best regards,
Fedde
Old 22nd October 2019, 07:12 PM   #1684
Logic800 is offline Logic800  United Kingdom
Mine was fine. A bow like that will stress the PCB tracks and likely lead to problems later even if OK now.
Old 22nd October 2019, 08:05 PM   #1685
ds23man is offline ds23man  Netherlands
ds23man's Avatar
Best regards,
Fedde
Both? Please contact Hypex support.
Old 22nd October 2019, 08:23 PM   #1686
ds23man's Avatar
Just checked it at a 252 floating around. A little bending because 2 fets are below the pcb. Not much and no problem for the pcb. Camera angles can be very unrelaible.
Old 22nd October 2019, 09:03 PM   #1687
Could you make a photo?
I already contacted Hypex RMA support by the way.
Fedde
Old 22nd October 2019, 09:10 PM   #1688
I attached a second photo where you can see better where the bending starts. I think the bending is too much, this must be an assembly issue...
Fedde
Old 23rd October 2019, 10:01 AM   #1689
YSDR is offline YSDR  Hungary
For FA, something would distort if the analogue input voltage given in the specification was exceeded? Or just the amps put out more power than the nominal and that's all?
Old 23rd October 2019, 04:16 PM   #1690
According to Hypex, the bend in the PCB is expected. All Fusion amps have this. Indeed the root cause is FETs that pushing the PCB up due to an isolation layer. So far they have not experienced issues with this...
Still not so happy about this though... I think it is a design issue...
Fedde
The New Hypex Fusion Plate ampsHide this!Advertise here!
Hypex Plate Amps madtrapper Class D 1 14th March 2014 06:21 PM
Opinions wanted on using the Hypex 2.4 plate amps? SpinMonster Multi-Way 2 3rd April 2012 09:26 AM
Hypex plate amps chatziva Class D 3 29th July 2010 04:33 PM
HYPEX plate amps Glen1 Subwoofers 0 27th January 2006 03:22 AM
Copyright ©1999-2019 diyAudio
